ragingbull10 Posted May 30, 2014 Share Posted May 30, 2014 I've just bought a POD Studio UX1 and downloaded Pod Farm 2.5. It works fine as a stand alone but in my DAW (Reaper) there is no output.How to fix? Quote Link to comment Share on other sites More sharing options...
Triryche Posted May 30, 2014 Share Posted May 30, 2014 Do you have your speakers connected directly to the UX1? Are selecting Line6 ASIO as your device in Reaper? Quote Link to comment Share on other sites More sharing options...
ragingbull10 Posted May 30, 2014 Author Share Posted May 30, 2014 Yes, I have speakers connected to the UX1. I've ensured that UX1 is enabled in MIDI devices. Have just tried selecting ASIO UX1 as audio device but apparently it keeps defaulting to ASIO 4 all which is what I normally use. Quote Link to comment Share on other sites More sharing options...
Triryche Posted May 30, 2014 Share Posted May 30, 2014 In Reaper, you need to select ASIO at the top of the menu. This will then change the drop-down options available in devices. Select Line6 ASIO UX1. In inputs enable 1 as the first and 4 as the last. Then in PF's mixer view you can configure what is sent to the 4 sends going to Reaper. Quote Link to comment Share on other sites More sharing options...
ragingbull10 Posted May 31, 2014 Author Share Posted May 31, 2014 If you mean te recorfing sends, they don't appear in Reaper, only in the standalone version Quote Link to comment Share on other sites More sharing options...
ragingbull10 Posted May 31, 2014 Author Share Posted May 31, 2014 all that appears in the mixer are the A & B input/outputs Quote Link to comment Share on other sites More sharing options...
Triryche Posted June 1, 2014 Share Posted June 1, 2014 In Reaper preferences in the Device Menu: Audio System: ASIO - this will change the available settings from input device to ASIO Driver. Select : ASIO UX2 This should give you access to the Enable inputs 1 thru 4 (first = 1 last = 4). In the POD Farm 2 mixer view you should see rec sends 1-2 and 3-4 with drop down options. A typical work flow is to capture tone A+B wet (1-2) and dry input (3-4) to your DAW, then you can add the PF2 plug-in to the dry track post processing. I typically arm two tracks to record, one receiving 1-2 and the other 3-4. The wet track is just a rough sketch/reminder for me and the dry has endless tweaking options with the plug-in.. I can post some screen shots if you need, just not sure how soon I can to to it. Quote Link to comment Share on other sites More sharing options...
ragingbull10 Posted June 2, 2014 Author Share Posted June 2, 2014 Thanks, I worked it out in the meantime (with a little help). The trick is, to select ''add new track'' rather than ''insert virtual instrument on new track'' i.e. an audio track rather than MIDI. Then, right-click on the record button and select "input monitor level" to get the output thru the monitors. PF2 can then be recorded as audio instead of MIDI. Presumably, this is because PF2 is VST as opposed to VSTi ? Quote Link to comment Share on other sites More sharing options...
Triryche Posted June 2, 2014 Share Posted June 2, 2014 Input monitor level is only to make the graphic appear on the recording track. I understand the confusion now. POD Farm 2 has 2 different forms, Tone Direct Monitoring (standalone) and Plug-In (VST/RATS). Launching POD Farm 2 form outside your DAW with the shortcut on your desktop or from your Start menu is the standalone version. This is the method you should use to make available to Reaper the4 sends from POD Farm. Launching POD Farm 2 from within your DAW creates and instance of the POD Farm 2 Plug-in. This is the method you should use to add POD Farm 2 models and effects to any previously recorded tracks. If you don't get it right away, no worries, I would search some youtube videos and/or ask more questions here and/or Reaper forums. As for MIDI, it contains no sound (just numerical information), and unless you have a MIDI controller, I would not worry about it at this point. Quote Link to comment Share on other sites More sharing options...
