xuabalc Posted June 8, 2014 Share Posted June 8, 2014 Hey, Is there a method to connect my POD HD 300 through a Flextone without used the amps and effects of the Flex ? Thanks for your answers/ Quote Link to comment Share on other sites More sharing options...
radatats Posted June 8, 2014 Share Posted June 8, 2014 Is there a method to connect my POD HD 300 through a Flextone without used the amps and effects of the Flex ? connect the unbalanced left and right outputs of the POD to the FX return of the Flextone III. Set the POD to Line and Studio and you should be good to go. Use both the POD master and the Flextone master to control volume. Quote Link to comment Share on other sites More sharing options...
xuabalc Posted June 9, 2014 Author Share Posted June 9, 2014 Thank's a lot Radatats. I try it this afternoon. I plug guitar in POD or in Flex ? Quote Link to comment Share on other sites More sharing options...
radatats Posted June 9, 2014 Share Posted June 9, 2014 Thank's a lot Radatats. I try it this afternoon. I plug guitar in POD or in Flex ? plug guitar in POD, Flextone is just a power amp in this setup. Everything is coming from the POD... Quote Link to comment Share on other sites More sharing options...
xuabalc Posted June 9, 2014 Author Share Posted June 9, 2014 Perfect job !!! You're a boss !! Just plug a gosht jack into the flex otherwise no sounds. Thank's a lot Radatats. Quote Link to comment Share on other sites More sharing options...
