Dshow Posted July 6, 2014 Share Posted July 6, 2014 Befor updating the firmware of my HD500 I did a backup of the whole Bundle. Then I updated the firmware and also overwrote the presets since I wanted to see if its something new in there. Then I imported my original Bundle again and I noticed that the names of the setlists didn't update. They are still named after the factory setlists. I mean the presets and setlists are all there but the names of the setlist not. I always give the setlist my own names and this is very annoing. I noticed this behavoir long time ago and thought it would have been adressed in a software update but is still there (might have been years). Anyone else having this problem? Quote Link to comment Share on other sites More sharing options...
silverhead Posted July 6, 2014 Share Posted July 6, 2014 Unfortunately that is normal behaviour. I would also like to see it fixed. Try resetting the Global Parameters, followed by a pedal calibration. This may restore the Setlist names that were saved/loaded with the bundle. If that doesn't work there are two workarounds that I know of: - Save and restore setlists individually rather than the entire bundle. A loaded Setlist file will set the Setlist name to the file name. - manually rename the setlists each time you load a bundle. ... And once you have the Setlist name restored in the editor, don't forget to SEND the Setlist to the Pod HD device. 2 Quote Link to comment Share on other sites More sharing options...
Dshow Posted July 6, 2014 Author Share Posted July 6, 2014 Thanks for your reply. It's such a pity - I think that would be a easy fix. I'll try your suggestions next time I do an update. Quote Link to comment Share on other sites More sharing options...
