M9 stopped working???
doomed23
First thing I'd do is hook it up to computer via midi and see if the Line6 interface on your PC can talk to it.
If you're lucky and it connects to your PC, I would back up your settings then re-install the latest firmware.
Good luck brother!
Good luck brother!
With line6 monkey? Ill try to do this tomorrow.Thanx.But what if that does not work?
If it won't connect to your PC then I don't think there's much more you can do by yourself. You could maybe try the Line 6 factory reset instructions, (easy to find on a google search), but I don't think you'll get very far with that as it needs the LED interface to navigate to the reset screen. If you can't get a midi connection with the Line6 interface then your best bet would be to look for an amp repair technician in your area and see what they say.
