Spdif sync problem with HD500
So,ever since I got a machine with Windows 7 a few years back I've had this problem, but it's gotten significantly worse lately.  Whenever my computer is restarted, my M-Audio Firewire Solo (with latest drivers) will not sync to the spdif of my Line 6 Pod HD 500.  It keeps saying 'mismatch', despite the sample rate matching on both.  Trying to toggle the sample rate on either, or both, does not fix the problem.  I have to continually reboot my computer until it will allow the sync.  There is no pattern that consistently works, such as turning on either unit first.  It has taken me as long as 45 minutes of continually rebooting before it works, and it's getting extremely old.  Does anyone have any ideas whatsoever that I can try???
Thanks for any help or ideas!
-Joe T.
You might try replacing the cable. I've used the SPDIF out successfully with no such issues many times.
The majority of which were on a mac, and i was also interfacing with a tascam us1800
one other thing to check might be the project properties in your DAW.
for example, the default sample rate is 44.1 on logic pro, and i can sync up and use my interface at a different sample rate all day long....
as soon as i open logic pro, 44.1 is forced and sync breaks... only fix is to close logic pro and re-sync at 44.1, or start a new project and change the sample rate beforehand.
