gthowe Posted August 1, 2014 Share Posted August 1, 2014 Hi I own a G30 wireless system and would like to use a power brick to avoid needing to use 3-4 different power adaptors for this and my effects pedals. Online resource indicates that the G30 adaptor provides 9v Dc at 500ma however I can't find any information that states what the minimum requirement is. I have been told by different sources that 9v DC at 250ma and 9v Dc at 400ma would be sufficient. Can you confirm what the minimum power supply requirement is for the G30 to help me identify possible power options please? Regards Gaz Quote Link to comment Share on other sites More sharing options...
dboomer Posted August 1, 2014 Share Posted August 1, 2014 Hey Gaz It's marked right on the receiver right next to the power pin. I don't have one in front of me but I believe that it is 200ma @ 9Vdc. Here's the deal. Often power supplies will sag even for a split second and only under the right conditions. That's why we only certify power supplies after a long QA process. The more units you have on the supply the more likely will come a time that you run low on current capacity. Now if at that moment you happen to light up an extra LED or two the tiny difference could send you into a temporary brown out. You'll get a drop out, not because the radio dropped out but rather because the power supply did. But it will feel like a radio drop. I'll bet this has happened a fair number of times and blame accessed to the wrong cause. Digital electronics will not give you any warning. If it were analog you would start to hear the sound deteriorating but digital will stay at 100% until it drops to zero. So all of that said, when I plan systems I always like to be able to supply double what is called out for. Quote Link to comment Share on other sites More sharing options...
gthowe Posted August 2, 2014 Author Share Posted August 2, 2014 Thanks for the prompt response, that's really helpful. I don't have my G30 at home with me so I hadn't realised that the info was marked on the unit. Regards Gaz Quote Link to comment Share on other sites More sharing options...
SiWatts69 Posted August 6, 2014 Share Posted August 6, 2014 Surreal that this question has been asked so recently... Don't ask why at this stage ;-) , but would it be feasible to run either a G30 or G50 receiver from a PP3 (9v) battery? Quote Link to comment Share on other sites More sharing options...
dboomer Posted August 6, 2014 Share Posted August 6, 2014 So this is a total guess and certainly not endorsed by Line 6 I would expect you might get about 1-2 hours use if you used alkaline and about 3-4 if you used lithium. Quote Link to comment Share on other sites More sharing options...
SiWatts69 Posted August 6, 2014 Share Posted August 6, 2014 Mmm... possible interesting experiment then... Hook the transmitter up to the M20d as send and feed a monitor signal down to be received, stick a mono earpiece in and... digital "in ear" ;-) Quote Link to comment Share on other sites More sharing options...
suttepikk Posted October 6, 2017 Share Posted October 6, 2017 My G30 receiver draws 117mA with sender off and 134 mA with sender on. Quote Link to comment Share on other sites More sharing options...
