windplayer Posted August 10, 2014 Share Posted August 10, 2014 If I start my pc (win 7, 64bit), the FBV-pedal is activated (diode).If I open the device manager in windows, there are no problems indicated with the usb-connection between pc and pedal (and also no driver problems).But nevertheless, the pedal does not work. If I open the FBV-control-center, you can read "No line 6 device connected".I have installed the newest updates (FBV-Control Center, Spider-monkey-software).If I then interrupt the usb-connection (short), it works all properly.I tried several usb-ports; it is the same problem at all usb-ports.Do you have an idea what to do? I do not want to interrupt the usb-connection everytime after windows has started... Quote Link to comment Share on other sites More sharing options...
fflbrgst Posted August 12, 2014 Share Posted August 12, 2014 I would not leave the pedal plugged in all the time. Plug it in only when you plan on using it. I assume this is for MIDI control of some device? I know it is not the answer you are looking for, but makes the most sense. Quote Link to comment Share on other sites More sharing options...
