lipsucnt Posted August 21, 2014 Share Posted August 21, 2014 Is it possible to have mixed input ie a vocal mic and guitar running with different effects for each input simultaneously and send them to different outputs ie vocals to pa and the guitar to the guitar amp as my pa has no effects other than reverb so I was going to feed my voice though the hd500x but can it be done the way I want to do it. Quote Link to comment Share on other sites More sharing options...
duncann Posted August 21, 2014 Share Posted August 21, 2014 There's no way to explicitly tell the unit to output x input at y output. But you could make use of the dual paths to achieve what you want. Set input 1 to guitar and input 2 to mic. Make sure the mixer balance controls are 100% left and 100% right and also that the mixer block is the last thing in the chain. Then the left output will be the guitar and the right output will be the mic. Here's a screenshot of a possible setup: Quote Link to comment Share on other sites More sharing options...
lipsucnt Posted August 23, 2014 Author Share Posted August 23, 2014 Awesome idea Duncann that keeps it simple and i like that. I will give it a try . Thanks Terry Quote Link to comment Share on other sites More sharing options...
chuberto Posted August 23, 2014 Share Posted August 23, 2014 Yes, it works as described. The only issue I discovered is the lag during patch changes which applies to both inputs ie the vocals will drop out whilst changing guitar sound. Quote Link to comment Share on other sites More sharing options...
duncann Posted August 23, 2014 Share Posted August 23, 2014 I think you'd be hard pressed to find any guitar processor that doesn't have some kind of lag during preset changes. Some have spillover of reverb and delay which helps to 'cover up' the change. If you can design your patches and any functions you might need within a single patch, any changes (turn effects on/off for instance) will be instantaneous as well as having tails for delay and reverb. Quote Link to comment Share on other sites More sharing options...
