vaud Posted September 25, 2014 Share Posted September 25, 2014 is it possible to record inputs at a level and NOT have them come out of the PA at that level? For example, I have four horns, drums, acoustic guitar and two vocals. Can I record the whole set up but only put the vocals and guitar through the PA? On a traditional board, you would bus them together and send them to the recorder and then turn them down in the main output but I can't find a way to do that on this board. Any suggestions? Quote Link to comment Share on other sites More sharing options...
Rick_Auricchio Posted September 25, 2014 Share Posted September 25, 2014 The block diagram shows the record/playback tapped from the input signal right after the input-gain section. So if that's correct, you should be able to simply pull the channel's fader all the way down to keep that signal out of the LR mix. Quote Link to comment Share on other sites More sharing options...
actdmusic Posted September 26, 2014 Share Posted September 26, 2014 Yes. I do this all the time! Even in rehearsals I do it. I set two scenes, one with only vocals up and all the other levels turned all the way down. Then another scene with a nice mix for playback. So we rehearse one song (recording) and the simply change the scene and we all listen back to our disgrace in a very nice studio mix style way! :P I can say this is the most valuable thing this mixer made for us! Always record the sounds and listen back in the rehearsal is very revealing and made all my bands sound a million times better! Quote Link to comment Share on other sites More sharing options...
Digital-sound Posted October 4, 2014 Share Posted October 4, 2014 Yeah, just turn down the levels of each channel. Make sure the input gain is set where you need and all channels receiving "input" will be recorded. Quote Link to comment Share on other sites More sharing options...
