jonaskarlberg Posted September 29, 2014 Share Posted September 29, 2014 Hi! I'm trying to synch the M13 with other devices, but I haven't been successful so far. I've tried to send the midi clock from a drum machine (Elektron analog rytm) and the Boss RC-300 loop station, but the tempo (when you access "settings") remains the same, regardless of tempo change from the other devices. I've tried the other way around, to send the tap tempo signal to the other devices, but that doesn't work either. I've set the midi setting in the M13 to "omni". I've also tried to set the midi setting to a specific channel and send the midi clock (from the drum machine) from the same, but nothing happens. Is there a crucial step or parameter that I am missing? The M13 is running FW 2.04. /Jonas Quote Link to comment Share on other sites More sharing options...
killit519 Posted October 20, 2014 Share Posted October 20, 2014 Did you have any luck? I'm also trying to midi sync my Beat Buddy drum machine to the looper on my M13 with no luck. I'd hate to have to buy a different looper. Quote Link to comment Share on other sites More sharing options...
macnevine Posted October 24, 2014 Share Posted October 24, 2014 I just posted this on the Mybeatbuddy forum: Update: I got my Line 6 M9 yesterday and tested the midi sync and it worked perfectly. My set up: Mybeatbuddy midi out to Midi in on Boomerang 3, Midi out on Boomerang 3 to Midi In on Line 6 M9. The clocks stay in synch perfectly on the boomerang and M9 and all my delays and modulations are in synch with MBB. I can Tap Tempo MBB and everything synchs to that tempo. I am one happy camper. But the M9 looper does not synch. Quote Link to comment Share on other sites More sharing options...
