FLYINGPIGZ86
How do I bypass effects
I just received the FX100 and would like to know how to bypass the effects and settings without having to use my itouch on stage. I would like to maybe set that as a preset.
I also would like to find a truly clean setting as well. I think the 2 things are basically the same.
Thanks
25 A,B,C and D are empty.
All you have to do is bank down from bank 1 and select A,B,C, o D.
You could also save the empty preset to anywhere you'd like.
But you probably won;t like it, unless it is for an acoustic electric.
A clean channel is not necessarily the same thing as no effects/models.
Look in the Clean amps category for a clean setting.
