134 Views 6 Replies Latest reply: Mar 17, 2013 9:40 AM by cragle007 RSS
cragle007 Just Startin' 4 posts since
Dec 28, 2012
Mar 15, 2013 3:52 PM
POD HD Desktop Setlist question
For some reason, the Setlist drop down in Edit only shows "Best of HD", "FX Heavy" and "Songs / Style" when my original boots of the device showed 4 Setlists.  I've tried a firmware reinstall, and have done a reset holding down the left arrow while plugging in the power.  Is there something I'm missing, or have I somehow changed the bundles so that a very limited number of presets are available?  Also, since I have a Spider IV, is there a way to get a tone that's preset on it into the bundles available on the POD HD?  Thanks for helping this newbie.
  • silverhead Expert Line 6 User 9,592 posts since
    Apr 1, 2009
    Mar 16, 2013 9:14 AM (in response to cragle007)
    Re: POD HD Desktop Setlist question
    Make sure you are running the latest version of HD Edit. Also, when reinstalling the firmware, be sure to say No when prompted whether you want to keep the existing presets. You need to overwrite the existing presets/setlists in order to reinstall the factory presets/setlists.
        Apr 1, 2009
        Mar 16, 2013 12:46 PM (in response to cragle007)
        Maybe I misunderstand, but in your screen shot I do see 4 factory-installed Setlists, and 4 User setlists. Note that a firmware reinstall does not rename setlists; you need to reset the Global Parameters, and then recalibrate the pedal after a firmware installation.
        http://line6.com/support/docs/DOC-2222
        http://line6.com/support/docs/DOC-2223
            Apr 1, 2009
            Mar 17, 2013 6:19 AM (in response to cragle007)
            Thanks for the clarification.
            Each firmware version contains a set of factory-installed setlists/presets for demonstration purposes, but these are not locked in any way - users can modify them. What you describe  indicates one of two things:
            - the last time your device had its firmware updated the factory installed setlists were different than they are now. Line 6 does modify the setlists  sometimes.
            - if the device is used, the previous owner changed some of the factory presets/setlists. Note that this can occur even during a trial period by a prospective purchaser who later returned the device, whereupon it is still sold as new.
            In any case, if you did not make a backup copy of the previous setlists (recommeded practice before any firmware update) then you can't retrieve them directly. If you know the names of the presets/setlists that you would like to restore you can post them here and perhaps some community member will have archive copies of them.
            The tones loaded on your Spider amp are not compatible with the Pod HD.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
