13766 Views 21 Replies Latest reply: Oct 14, 2011 9:28 AM by kdguitar61 RSS
frac82 Just Startin' 67 posts since
Jun 17, 2007
Jul 8, 2009 11:39 PM
Vetta HD 1 vs. 2 cabinets: speakers comparison
why the cabinet relative to Vetta1 HD has Custom Celestion speakers while the Vetta2 HD relative one has V30s? is there any difference in sound generation between the two heads to justify that? if yes, this difference can be overcome with the update? when using the V30s loaded cabinet you still allow CAB/A.I.R. emulation or bypass it to get the full potential out of the V30s?
i'm about buying a 2nd hand Vetta1 HD and i'd like to know if my 2x12" Celestion Classic Lead cabinet is "rubbish"...
thanx, bye
  • Line6Hugo Line 6 6,580 posts since
    Apr 8, 2007
    Jul 9, 2009 10:49 AM (in response to frac82)
    Re: Vetta HD 1 vs. 2 cabinets: speakers comparison
    frac82,
    All of the Vetta (I and II) cabinets used the same Custom 12" Flat Response Celestion speakers:
    http://line6.com/cabinets/vetta.html
    The Vintage 30s Celestions are not flat response and will color your tone with the sound of the Vintage 30s if you choose to put these speakers in a cabinet to use with your Vetta II.
    Regards,
    Lin6Hugo
  • ricksox UberGuru 11,600 posts since
    Mar 28, 2006
    Jul 9, 2009 1:41 PM (in response to frac82)
    The decision to put V30's in the newer Spider Valve cabs was collectively made by the design team at Line 6 along with Reinhold Bogner simply because they liked the way it sounded. It doesn't go any deeper than that.
    Line6Miller
        Apr 8, 2007
        Jul 9, 2009 3:32 PM (in response to frac82)
        The Spider III Cabinet has the same Custom Celestions as the Vetta cabinet does.  As Miller mentioned, the Line 6 Spider Valve Cabinet is the only cab with V30s in it for the reason mentioned.  You don't have to use one cab over the other as long as it sounds good to you, but Line 6 does make a 4x12 cab with either set of speakers.
        Regards,
        Line6Hugo
    Apr 8, 2007
    Jul 10, 2009 11:03 AM (in response to frac82)
    Before the Spider Valve Head was released, there was a another Line 6 4x12 cab other than the Spider III Cabinet for use with the Vettas and HD147 that carried the Custom Celestion speakers. That cabinet was discontinued after the V30 4x12 for the Spider Valve HD100 was introduced. Since then, there has been no official 4x12 Vetta cabinet. But that does not mean there are no cabinets to be used with the Vetta, as the V30 cabinet is perfectly compatible for use with the head as the webpage says, though the V30s will color the tone. Some people find this desireable, some don't. The Spider III cabinet is also perfectly compatible with the Vetta head along with any other cabs from another manufacturer with a matching load from the cab to the Vetta head.
    We here in support are here offer additional information to supplement the website or manuals with public info on our products. So, though it may not say on the website that you can use the Vetta HDs with a Spider III cabinet, I am here to tell you that, yes, you can use it with the Vetta HDs along with any other speaker cabinets with proper matching loads.
    Regards,
    Line6Hugo
        Mar 28, 2006
        Jul 10, 2009 2:37 PM (in response to frac82)
        then i see the Vetta HD with its V30s cabinet ; once again i think that's ok because something inside the head internal circuitry/firmware differs from the combo one and yields better with colourful vintage speakers...
        There is nothing inside the head, internal circuitry or otherwise that is different from the combo. We load the combos with custom flat respnse celestions. We discontinued the old 4x12 flat response cabs and replaced them with the V30's. Not sure why. It was a development decision.
        Line6Miller
          • jvblack Iknowathingortwo 190 posts since
            Oct 20, 2007
            Jul 11, 2009 11:29 AM (in response to frac82)
            • I have a combo and i love the way it sounds.  Never used a head/cab setup with the vetta.
            • Why not get two small, full range PA cabs and run them in stereo instead of a 4X12 guitar cab.  It's probably easier to transport and carry, and should be plenty loud.  I've run my combo this way a couple of times with the internal speakers disabled, and it sounds AMAZING.  Being able to separate the left and right speakers really enhances the stereo aspect of the amp.  If i had to do it over again, I'd get the head and do that.  Maybe you could try it at rehearsal or take your head to a local music store and try it.  Don't buy a big, expensive 4X12 until you do.
            I'm pretty sure some of the users of the various pods do the two speaker thing with a power amp.  You might check out some of the pod forums here and in the archives.  There's no reason you couldn't do the same thing with a Vetta head using it's own internal power amp.
            The cab models are (in my opinion) a great resource.  You shouldn't have to give them up just because Line 6 doesn't make a cab.  There are speakers out there that can do the trick.
            Hope this helps,
            Joe
              Oct 20, 2007
              Jul 11, 2009 11:26 AM (in response to jvblack)
              Forgot to mention:
              The first time i did it, i used two little PA cabs with 1 - 12" and a horn.  It sounded really good, but i don't remember the brand of cab.
              The second time i tried it, i used two Peavey PV215's.  They have 2 - 15" and a horn, and they sounded incredible.  However, they're about 80 pounds each and i wouldn't want to pack them around.  However, with the 15's the low end was nice and smooth without being boomy, and the highs were very smooth without being harsh.
              If i were shopping for this rig, i'd probably look for something with 1- 15 and a horn with a pretty flat response.
              Joe
                  Oct 20, 2007
                  Jul 13, 2009 3:44 AM (in response to frac82)
                  My point is this:
                  If a suitable full range, flat response 4X12 stereo speaker cabinet cannot be found, one could simply use two small full range PA type cabinets instead to take advantage of all the cabinet modeling features of the Vetta head.
                  One could also use two of the Vetta 2X12 extension cabinets.  There seems to be a few retailers that still have them in stock.
                  Joe
  • Line6Andy Line 6 4,345 posts since
    Jun 5, 2006
    Jul 13, 2009 9:27 AM (in response to frac82)
    If you are interested in acquiring the Vetta "flat response" speakers, you can still order them directly through a Line 6 dealer.  Another option would be finding a dealer that has a new or used Vetta cabinet is stock so you can compare the sound yourself.
    • drunkuilled Just Startin' 2 posts since
      Oct 11, 2008
      May 13, 2010 6:56 AM (in response to Line6Andy)
      Hi guys,
      I seem to have a problem with Vetta II.
      When I plug in the full-range PA-box to the amp-out it sounds really bad - lot's of distorted high frequences (from the horn). When I use the cheapest PA amp and go direct out from the vetta to the pa-amp and to the same speaker - it sounds awesome.
      How can this problem be solved? Obviously it is a problem of the poweramp inside my vetta - is it supposed to be working? Or is there something wrong with the vetta?
      Another problem or feature that I don't understand is why on the output page I have the selection between 2x12 and 4x12 when I already specified on my cabinet modelling that I use for example 1x15 thunder? I could probably understand that for usage of the external speakers but why does it affect the direct out??? Can i switch that off? For example POD X3 doesn't have this option on the direct out and to my ears it sound much better.
      Cheers,
      Sergey
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
