3312 Views 10 Replies Latest reply: Mar 12, 2012 9:41 AM by BuddhaMaster RSS
rdmarshall Just Startin' 4 posts since
Nov 26, 2008
Mar 13, 2009 10:22 PM
My guitar is too quiet for Backtrack. How can I boost the sound?
Ok, I have a classical guitar, it does have a built in pickup but it is not a battery powered one. My backtrack recordings are too quiet. Another side effect of the quietness is that it breaks up my songs (which have quiet spots in them) into multiple files. The third side effect is that each file is missing a few notes in their beginnings because of the automatic startup nature of the Backtrack, makes it wake up just a second later.
I think this is a cool product. By far the best feature to me is the portability factor. So, how can I boost the sound without complicating the setup (e.g. carrying some kind of portable preamp??)
Thanks in advance,
Dan
  • Jeraxle Just Startin' 184 posts since
    Nov 28, 2007
    Open your configuration software (should be preloaded on the backtrack, if not, go to the downloads page and grab v1.03).
    Depending on if you have the backtrack or backtrack+mic, the config utility will look slightly different.  Either way, check to make sure that you have the autocapture settings set to "Soft".
        Nov 28, 2007
        This seems like a PITA, but if you have all of your settings set to soft and the volumes cranked, my next step would be to force capture all my recordings and run the wav files through my DAW (Reaper) for a signal boost.
        That's a bit extreme however.  I mainly do stuff like that just to see if it'll work. =)  Other than that, do you have another guitar you can use to test out your BT?  If we can isolate the problem down to your pickup, it may save you time, money, and frustration in the long run.
          • howellnorfolk Just Startin' 15 posts since
            Mar 22, 2009
            I wasn't having trouble getting a good level once the thing records but I was having trouble keeping it recording on autorecord - I tried raising my neck pickup a little and that helped but then I changed the settings for the amount of silence it will handle before it cuts off - so I maxed that out to the 5secs and then I lowered amount of time it takes to split into another event..down to the lowest setting. This seems to work ok now. It seems to record continuously even at light touches on the strings. If your not getting volume out of it there may be something wrong with it..I have a nylon string guitar with a bridge type pickup and I will try that and report back.
  • Rowbi Expert Line 6 User 7,745 posts since
    Nov 25, 2006
    yeah using a normalise function in a DAW would hopefully increase your volume on the track, but that isn't ideal.
    if you can't adjust the backtrack any more to get more gain on the record level, how's about this for a thought... are you just plugging your guitar straight into your backtrack?  if so, is your volume at full?  maybe you usually play with your volume low to get the right sound, but that may mean the volume level of your recording isn't high enough.  do you play into an amp that might have a recording direct output?  another option if you aren't trying to lower your guitar output to get a specific tone, you could try boostingyour volume level by getting an EQ pedal, and turning the level control up a little?
    just some ideas to think about
    regards
    rowbi
  • rmeason Just Startin' 1 posts since
    Mar 15, 2009
    I just purchased Back Track and found that the only way I can get a signal strong enough to import was to use the Phones jack or mono out on my amp.
    Worked ok, crappy sound.
    Pushed everything up to fill volume and barely got a wisper directly out from the Guitar.
    Playback through the amp was ok just not a stong enough signal to be read by anything except I tunes.
    Equipment:
    Martin dcme w/fishman
    Breedlove G5
    Roland amp
    Martin HD 28 w/fishman
    I had hopes for a $100.00 solution.
    Rob
  • BuddhaMaster Just Startin' 5 posts since
    Aug 31, 2011
    Hey everyone I got the exact same problem.
    I have to hit the strings pretty hard, I also set BACKTRACK 'capture' level to soft.
    Setting pickup position to middle or neck-middle helped a lot.
    It makes me able to play a whole passage hitting pretty hard and keep recording.
    The resulting audio file is still about 5% maximum volume of 100%
    Thats a lot of quality waste!
    If Line6 PLEASE could update their firmware with freedom of dB capture level lower than soft that would be very good for a lot of people.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
