Aug 4, 2009 3:59 AM
.wav file format into .jam file format
Like (0)
Hi to everyone !
Jamming with a Line 6 Spider Jam amp, I am looking for a software (if it does exist, which is something i do not know) that will change your .wav files into .jam files to be used in the SD card and into the Spider Jam amp.
Can anybody tell me if this software exists ? If so can you tell me where to download it ?
Once again thank you in advance for your help and...let's keep jamming !!
All the best
Jean Claude
ps: please answer to this e-mail adress : jcdebieve@gmail.com
This is not necessary. The Spider Jam can load and play WAV files provided they are mono, 16-bit and 44.1kHz. Just copy them onto the card and use SAVE: TRANSFER RECORDING FROM CARD. You can then assign a tone and resave it as a .JAM file.
Every time I try to save to the SD card as .wav I have a "card read error". Has no problem saveing the .jam file to the sd card however. Any Ideas?
i have this problem too
When you can't save a WAV file to an SD card, it is usually because the card is not formatted fully. With some cards, you need to run the format routine several times so try formatting the card 10 times. This usually does the trick.
+1 to that...
Thanks
Line6Sach
