5695 Views 3 Replies Latest reply: Aug 12, 2010 1:54 AM by cbult1 RSS
janneskruger Just Startin' 1 posts since
Jul 6, 2008
Aug 11, 2009 5:50 PM
Line 6 Floor Pod Plus
I bought this line 6 product today, i see the the delay has a knob that you can turn on how much delay you want, you can even turn it off, then the led turns off. But the effects tweak knob does not let me turn off the effects, is that normal.
  • LoonyBin-Fizzbin Gear Head 2,071 posts since
    Mar 26, 2007
    Aug 12, 2009 5:28 AM (in response to janneskruger)
    Re: Line 6 Floor Pod Plus
    Are you asking on how to turn off all the effects at once? Or ?
    Bank Up/Down – These footswitches select banks 1-31. To scroll through banks quickly, hold a footswitch down until you get to the bank you want. Press both footswitches together to choose modes as we’re about to describe...
    Footswitches A-D – There are two footswitch modes; Channel Memory and On/Off. To toggle between modes press both bank up and down simultaneously.
    • Channel Memory Mode: In this mode Bank Up and Bank Down selects a bank while Footswitches A-D select a Channel Memory within that bank. In this mode, the footswitch lights will illuminate Red when the footswitch is pressed.
    On/Off Mode: This mode lets you to turn effects or the Amp Model on and off with your feet. Footswitches A-D now turn on and off the Amp Model, Solo boost, FX, and Delay respectively. In this mode, the footswitch lights will illuminate Green to indicate the On state of each function.
    On/Off Functions Light – Lights when On/Off mode is active.
  • Line6Hugo Line 6 6,580 posts since
    Apr 8, 2007
    Aug 13, 2009 9:17 AM (in response to janneskruger)
    +1 to Looneybin
    Regards,
    Line6Hugo
    Please make sure to award points to helpful & correct responses to your questions.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
