4685 Views 5 Replies Latest reply: Aug 14, 2009 11:22 AM by Line6Hugo RSS
tambey Just Startin' 2 posts since
Nov 29, 2006
Aug 12, 2009 10:11 PM
flash memory still unknown
Hi, recently my PODxt suddenly not able to use with Gearbox and Edit. I check with Monkey, flash memory display unknown. I'll manage to update it using usb, midi to usb cable, safemode. But the Monkey still show the flash memory unknown.
Please somebody help me. Thank you.
  • Rowbi Expert Line 6 User 7,745 posts since
    Nov 25, 2006
    Aug 13, 2009 12:40 AM (in response to tambey)
    Re: flash memory still unknown
    it sounds like you may have a problem with your POD.  did this just start happening?  and it was okay before that??
    there's no way to actually reset the PODs that I know of, as reinstalling the firmware effectively does the reset.  it might be worth you calling line6 tech support in 8 hours when they start work (they're in california) and having a chat with them about it, as they may know a trick or two.  apart from that, it's probably in need of a service.
    Cheers
    Rowbi
      Nov 25, 2006
      Aug 13, 2009 4:51 AM (in response to tambey)
      get in touch with your closest line6 service center for a repair: http://line6.com/support/serviceCenters/
    • LoonyBin-Fizzbin Gear Head 2,071 posts since
      Mar 26, 2007
      Aug 13, 2009 6:03 AM (in response to tambey)
      Have you tried to Re-install all your Line 6 Software?
      You may just have a corrupt Driver, and you will not be able to resolve this until you Remove all you Line 6 Software, and then Start from a new download & Install!
      Please do not Connect your USB until the Line 6 Installer asks you to do so! As well Accept all conditions that are asked of you! (If Vista, look for a check box that you need to accept before continuing on to the "Next" phase)
      In other Words, take your time to read everything before you click Next or Continue!
  • Line6Hugo Line 6 6,580 posts since
    Apr 8, 2007
    Aug 14, 2009 11:22 AM (in response to tambey)
    +1 to LooneyBin
    I recommend disconnecting any other USB devices from your computer (except for a mouse and keyboard) while troubleshooting this issue.  Completely remove ANY USB hubs from the computer and test the PODxt on all of the USB ports on the computer.
    If it fails to work, I recommend trying on another computer to isolate the problem.
    IF the problem is still present, you will need to take the PODxt to an authorized service center.
    Regards,
    Line6Hugo
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
