3229 Views 3 Replies Latest reply: Aug 21, 2009 11:55 AM by ricksox RSS
jbelt Just Startin' 4 posts since
May 3, 2006
Aug 18, 2009 10:37 AM
Sample Rate Issue w/Cubase
A question about sample rates via a USB connection to DAW. With a Pod XTPro, what is the sample rate available to USB connetion to DAW? I see that up to 96KHz is available, but Cubase's clock gets royally tanked everytime I try to link up Pod with file recorded at 96K. Only solution was to downgrade sampling rate of recording to 44KHz & 24 bit. Problem is solved with that approach, but it did raise a curiosity on how the sampling rates are managed via the varios digital outputs on the Pod.
Thx,
j
  • Line6Hugo Line 6 6,580 posts since
    Apr 8, 2007
    Aug 19, 2009 11:46 AM (in response to jbelt)
    Re: Sample Rate Issue w/Cubase
    j,
    The sample rates for the digital outputs are managed using the 'I/O & DIG SELECT' menu on the PODxt Pro which can be access by pressing the button on the faceplate with the same name. The Format option in the Digital Out menu allows you to select the bit depth and sample rate that the PODxt Pro will output from the Digital Outs.
    You must also make sure that you are matching these specs in Cubase when you create your project settings.
    Regards,
    Line6Hugo
  • ricksox UberGuru 11,600 posts since
    Mar 28, 2006
    Aug 21, 2009 11:55 AM (in response to jbelt)
    Hello,
    The USB connection will sample up to 48K but won't go beyond that. If you want a higher sample rate then yes, you'll need to use either the SPDIF or AES digital outputs.
    Line6Miller
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
