Line 6 - Support
3209 Views 6 Replies Latest reply: Aug 26, 2009 11:14 AM by aural RSS
jspann7 Just Startin' 5 posts since
Jul 15, 2007
Aug 24, 2009 7:31 PM
Recording POD X3 through SPDIF
Hello,
I am trying to connect my POD X3 to my computer to record using SPDIF.
I have a 75 ohm cable going from the POD into a Creative Digital I/O Module (http://www.soundblaster.com/products/product.asp?category=1&subcategory=16&product=1780) going into my sound card (http://au.creative.com/products/product.asp?category=209&subcategory=669&product=17813&listby=) through the rear line in port.
I have the output on the POD set to match the studio direct. There is 12dB of gain on the SPDIF output at 44.1 kHz. My sound card has the line in turned up, the pod master volume is turned up and my speakers are all turned up.
When I run my recording software, no signal is recieved or detected.
Can you please help?
Thanks,
Joel
  • aural Just Startin' 70 posts since
    Jan 24, 2007
    Aug 25, 2009 7:54 AM (in response to jspann7)
    Re: Recording POD X3 through SPDIF
    Usually "Line In" refers to an analog inout at line level, not a digital spdif input. Are you sure your interface has spdif and not just analog RCA/phono jacks?
    Also, sync needs to be set to "external" or "spdif" or whatever it is called in your card's setup panel.
        Jan 24, 2007
        Do you have 2 separate devices then- a digital to analog convertor and a sound card?
        At any rate, the second part of my response is critical- your other gear must slave to the X3 through spdif. Is there an applet that lets you make settings to your hardware, so you can choose to sync to an external digital source?
  • Line6Andy Line 6 4,345 posts since
    Jun 5, 2006
    Aug 26, 2009 10:24 AM (in response to jspann7)
    Hello,
      If your soundcard does not have a SPDIF connection, it is most likly not seeing the "digital" output of the POD.  Have you tried using the analog outputs of the POD and are you getting signal there?  Do you have another SPDIF interface you can try connecting to for trouble shooting?
      Jan 24, 2007
      Aug 26, 2009 11:14 AM (in response to Line6Andy)
      He is using a digital convertor box from Creative that is supposed to output the (analog) signal to his sound card.
      After reading a few comments/reviews on it from Amazon, it seems like many people have problems with it though...
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
