1 ... 6 7 8 9 10 Previous Next 92500 Views 147 Replies Latest reply: May 16, 2010 7:48 PM by MasterSimons RSS Go to original post
  • hookshot Just Startin' 8 posts since
    Feb 5, 2007
    135. Nov 3, 2009 12:43 PM (in response to FazFlash)
    Re: Sound suddenly choppy/distorted
    add me to the list. mbp (late 2008) with 10.6.1, 4gb, 500gb hdd and drivers 4.2.4
    line6, this is gettin really annoying. and stop blaming apple for everything. other audio producers dont have these problems.
  • andr3vv Just Startin' 3 posts since
    Dec 30, 2009
    136. Dec 30, 2009 6:08 PM (in response to mrko5)
    im having the exact same problem only it happens every 30 second so the things completely useless ill never buy ;ine 6 again
  • FazFlash Just Startin' 2 posts since
    Aug 3, 2009
    137. Dec 30, 2009 9:13 PM (in response to andr3vv)
    My problem solved after  I installed 4.2.5 driver. No more distorted sound.
    http://line6.com/community/docs/DOC-1576
  • GHPoe Just Startin' 1 posts since
    Mar 7, 2010
    138. Mar 14, 2010 8:55 PM (in response to mrko5)
    I am getting this about everytime I sit down and try to use the UX2.  A reboot fixes the problem.
    In POD Farm if I goto about it says I am using version 4.22 so is the problem back?
  • dmorgen Just Startin' 14 posts since
    Jan 30, 2007
    139. Mar 15, 2010 5:57 AM (in response to GHPoe)
    I'm also getting the problem again frequently when I start Gearbox.  I'm using a GuitarPort on Snow Leopard.  Generally, I can solve the problem by unplugging the USB cable, then plugging it back in.
    Dave
  • ax42 Just Startin' 4 posts since
    Aug 13, 2006
    140. Mar 15, 2010 6:38 AM (in response to dmorgen)
    Similar but opposite problem here - everything is fine after a reboot, but if I unplug/replug the Toneport (eg to move the laptop) I always get choppy sound.
  • drice Line 6 27 posts since
    Feb 25, 2008
    141. Mar 15, 2010 11:08 AM (in response to ax42)
    Can you all please confirm the driver version that you are using listed in the Line 6 Control Panel?
    Thanks for your feedback.
    -Dan
    Jan 30, 2007
    142. Mar 15, 2010 11:34 AM (in response to drice)
    Driver Version 4.2.5..
    I just remembered another problem ... the last few times I've started Gearworks after using my system for awhile (I haven't narrowed it down further), my system totally hangs.  The only thing that works is cursor movement, but not clicks.  I can't force quit, restart, etc. ... I must power down & up to get back going.  But if I start Gearworks immediately after the startup is completed, there are no problems, even if I use it on & off for hours (I haven't actually timed it).
    Dave
    Feb 25, 2008
    143. Mar 15, 2010 11:40 AM (in response to dmorgen)
    OK you're not running the latest driver or gearbox. Can you please i nstall Gearbox 3.72 and let me know if your problems persist? The latest mac driver is 4.6.8 which has official support for Snow Leopard.
    Aug 13, 2006
    144. Mar 15, 2010 2:36 PM (in response to drice)
    How does one install this version of the driver?  I had to install my current version (4.2.6) by choosing a beta download off the website.......  Will Line6 Monkey install the correct version for me?
  • ricksox UberGuru 11,600 posts since
    Mar 28, 2006
    145. Mar 15, 2010 2:39 PM (in response to ax42)
    Hello,
    Gearbox 3.72 is slated for release later this week so you won't see it just yet. Download the latest non beta driver (4.6.8) from our software downlaods page and let us know if you continue to suffer from glitches on playback. Thanks.
    http://line6.com/software/index.html
    Line6Miller
  • wkriski Just Startin' 7 posts since
    Feb 13, 2008
    146. Mar 22, 2010 6:48 PM (in response to ricksox)
    I have 4.68 mac driver and am getting crackling with podxt on imac in the latest garageband. If I turn down the channel vol or turn on the tuner the crackling stops (just fyi). There also doesn't seem to be the crackling when I record myself in iMovie. I'm assuming it's a mac driver issue as it works fine on my pc (I just checked). I increased the buffer to full size and it still happens, turned off airport. It seemed to be working fine until the last couple days. I reinstalled garageband and variety of other attempts with Apple support until we ran of out things to try (reset power management, p ram, etc).
    Please advise.
    Thanks
  • MasterSimons Just Startin' 1 posts since
    Jul 7, 2006
    147. May 16, 2010 7:48 PM (in response to mrko5)
    Hey, I need help on this same issue. I have a macbook pro with a TonePort UX2. It runs perfectly fine and plays audio back just fine. However, if i unplug the usb from the mac, and i plug it back in, it starts the nasty crackling when i play an audio file. I need help with this. A simple restart solves the problem, but i don't want to have to restart my computer every time i plug in my TonePort. Any suggestions Line6 Team or anyone else? If not, then there should definitely be a patch if this is a software issue.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
