9560 Views 5 Replies Latest reply: Mar 16, 2012 7:18 AM by RedWing2012 RSS
th3l0rd Just Startin' 2 posts since
Aug 29, 2009
Sep 20, 2009 6:34 PM
clean tone on line 6 spider iv 15
how do i get a clean tone on spider iv 15 - i.e without the echo? i have reset the amp too - i switch on the amp on the clean channel and the tap light keeps blinking...
  • Kneehow UberGuru 6,750 posts since
    Dec 26, 2007
    Sep 22, 2009 2:21 PM (in response to th3l0rd)
    Re: clean tone on line 6 spider iv 15
    Save your Clean tone without the Echo effect or Mod effect. Next time you have the amp on, select Clean. Then turn the Echo knob to the right then all the way back to the left (OFF). Do the same for the Mod knob.
    To save, hold the Clean button down for 3-5 seconds. The LED's will blink a few times. The Clean sound now will not have any Mod or Echo effect present. Power off the unit, back on and verify that the Clean is still dry as you just recently saved it to be.
    Regards,
    L6Perry
    • calum_stout Just Startin' 4 posts since
      Sep 26, 2009
      Sep 29, 2009 4:13 AM (in response to Kneehow)
        I have a spider iv 15.
        Does the trick for saving the "clean" settings also work with the other three channels?
        i.e. When you have a setup you like on say crunch, do you just press it until it flashes?
        Also when you "save" the setting, will it default to the "last saved setting" when you
        switch between say crunch->clean, or will the new amp model take the existing knob
        settings?
        I think this is a good feature that you should explain in an "advanced" manual (together with
        the tuner, boost/gate toggle and "factory reset" settings.
        thanks a lot,
          Calum
        Sep 26, 2009
        Sep 29, 2009 11:58 AM (in response to calum_stout)
          I found the answer in the "Spider III 15.pdf" manual.
        It's a much better manual than the Spider IV 15 pilot manual.
        Calum
        Channel Memories / Amp Models
        The four channels each use a different Amp Model, and all come
        pre-loaded with a factory preset dialed in to nail a great tone. Press
        one of these buttons to hear the presets. To replace any preset with
        your own “snapshot” of all tone and effect knob positions (except
        Master Volume), press and hold one of these four buttons for two
        seconds. The light flashes when the save is complete.
  • RedWing2012 Just Startin' 3 posts since
    Mar 15, 2012
    Mar 16, 2012 7:18 AM (in response to th3l0rd)
    Thanks for the "fix" for this aggravating "Bug". I had it figured out that by turning effect knobs to full on then back to 0 I would get it clean, however, when changing to another preset then back to clean, the effects were back on again. The advice of turning knobs full on then off then holding down clean button till other settings flashed saved the clean setting. Now when I turn on amp the clean channel is just that-clean! Thanks, Tommy G. Redwing 2012
Bookmarked By (1)
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
