3284 Views 6 Replies Latest reply: Nov 13, 2012 4:01 AM by fakecrusader RSS
JackMajdecki Just Startin' 2 posts since
Apr 7, 2006
Sep 27, 2009 9:01 PM
Neck Adjustment Tool for Variax 700
Is there a way to get replacment tools, such as the neck adjustment tool for the Varuax 700.  If not, are the specs available to find a replacement.
  • Crusty_Old_Rocker Expert Line 6 User 3,096 posts since
    Jan 24, 2007
    Sep 27, 2009 9:55 PM (in response to JackMajdecki)
    Re: Neck Adjustment Tool for Variax 700
    Just buy yourself 2 sets of Allen Wrenches, 1 metric and 1 imperial.  They have 1000 + 1 uses around the home and workshop and they'll only cost you a few bucks.  You can get them from any hardware store.
    Cheers,
    Crusty
        Jan 24, 2007
        Sep 28, 2009 4:16 PM (in response to JackMajdecki)
        Gee, I have not had to adjust the neck on my 700.  The 600 adjuster is exposed and that is just an Allen type.  I have not take the cover off the 700 to peek at the adjuster.  Perhaps I should.  The guitars only come with Allen wrenches and that's why I presumed the 700 would have the same type of truss rod adjuster.
        Line 6 don't have anything listed in their parts store.  I have never had a problem with truss rod adjusters as I have a collection of tools from guitars past.  Including small socket wrenches.
        The curiosity is going to get to me now and I'll have to take a look at the neck adjuster on the 700.
        I have a socket set with 14" drive and T wrench that I use for guitars that have a hex nut type adjuster at the head.
        Cheers,
        Crusty
  • Line6Hugo Line 6 6,580 posts since
    Apr 8, 2007
    Sep 29, 2009 5:36 PM (in response to JackMajdecki)
    Jack,
    Please check out the following knowledge base document for the specifications you are looking for:
    http://line6.com/community/docs/DOC-3733
    Regards,
    Line6Hugo
  • fakecrusader Just Startin' 1 posts since
    Sep 7, 2008
    Nov 13, 2012 4:01 AM (in response to JackMajdecki)
    The Line 6 documentation is incorrect or there are undocumented variations in the models. My Variax 700 electric requires a 7mm hex socket, as the truss rod has a hex nut (male) and not a hex inset (female) - that is, adjust as you would for a Gibson truss of this type.
    You can get these wrenches from online guitar shops - I needed to get a 'proper' wrench as there is not enough room to fit the more general types of 7mm hex wrench or ring spanner you might have.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
