Oct 13, 2009 7:54 PM
BackTrack +mic problem
Like (0)
I have a BackTrack+mic and my pc with with WinXP does not recognise my usb device (Backtrack) I downloaded the software from your site to see if that would help but it did not. The BT is blinking green-green-red-green-red I believe. It does not shut off. It was working fine for a while when using it today. It recognized it when I first hooked it up to my pc earlier but then the pc started bleeping the usb port on and off several times. I am not sure if it is charging. Can you help me with this problem?
Thanks,
Phil
Hello,
The first thing you should try to do is isolate the problem. Have you tried a different USB cable? How about a different USB port?
Have you tried a hard reset on the unit? See the following FAQ for instructions on how to do that.
http://line6.com/community/docs/DOC-4769
Lastly, try the BT on another computer to see if it behaves the same way.
Line6Miller
