4624 Views 5 Replies Latest reply: Oct 26, 2009 10:01 AM by frasergray RSS
harranjo Just Startin' 3 posts since
Oct 16, 2009
Oct 16, 2009 3:22 PM
Broken Verbzilla Pedal...Please Help!!
Hi, I just recently purchased a verbzilla pedal off of ebay, and just received it today. Unfortunately, when I tried playing through it, it kept making this popping noise....like a metronome or something, just going pop......pop.....pop.....pop. And it does this when it is not even turned on. When I try to turn it on, it doesnt do anything, it just keeps making the popping noise. And when I depres the pedal all way down to the point of it clicking, the LED flashes a green light and red light for a second. When the light flashes, the noises stops. The lights only turn on for a second though, and then it just goes back to popping. I've tried using a battery and a power supply, and its the same story. Does anybody know whats wrong???
  • Kneehow UberGuru 6,750 posts since
    Dec 26, 2007
    Oct 16, 2009 4:08 PM (in response to harranjo)
    Re: Broken Verbzilla Pedal...Please Help!!
    You could also try removing the module and inspecting the connection points between it and the dock. You'll need a hex/allen wrench to remove the two hex bolts on the side of the dock. Press gently on the circular black plastic release below.
    If the connection points are clean and not visibly damaged, try re-seating the module back into the dock. If the situation is the same after this, you probably need a new module or dock. (Which means you were sold a malfunctioning unit from the seller).
    Regards,
    L6Perry
    Dec 26, 2007
    Oct 19, 2009 10:07 AM (in response to harranjo)
    Yes... but you'll need to physically A/B your device(s) against a known good unit to really identify which one is failing.
    If you live close to a Guitar Center, you could take your pedal there and ask the guys in the Accessories Department if they could let you try out a verbzilla unit to A/B against yours. I'd mark both your module and dock with tape so you know which components are yours.
    Try your module in the store's known-good dock. If it passes signal, obviously the module is OK and you'll need to buy a new dock. The opposite would be true. Worse case scenario is that both module and dock are failed. In that case, you should probably contact the seller that you purchased this from and see if he/she can do anything for you as you purchased a malfunctioning used unit from them.
    Regards,
    L6Perry
  • frasergray Just Startin' 1 posts since
    Oct 26, 2009
    Oct 26, 2009 10:01 AM (in response to harranjo)
    I currently have the same problem with my verbzilla.
    I purchased the unit (new) late Nov. last year and one day last month it stopped working. I wasn't using the unit at the time (I have used it infrequently to be honest, however is a fantastic pedal), and when I switched it on next I was surprised to find no signal being passed, only a small popping noise. Again I have tried battery and power supply.
    Is this still covered under warranty and if so, should I contact the place of purchase or go direct to line 6?
    Thanks
    Fraser
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
