4689 Views 4 Replies Latest reply: Oct 22, 2009 12:40 PM by CptTripps RSS
crazycottydude Just Startin' 8 posts since
Aug 7, 2008
Oct 17, 2009 11:37 AM
POD Farm Crashes UX8 Hardware driver
I am using pod farm with my L6 UX8. When i launch the standalone program of pod farm it crashes the drivers on the ux8 as the red lights saying driver on them flash up red. the same problem happens when i try to load up the pod farm plugin. I have managed to funnel the problem down to just the pod farm application as this problem only occurs when i load it up.
The driver and software versions are:
Driver: 3.4.3.8
PodFarm: 1.11
Line 6 Monkey: 1.31
USB Firmware: 1.00
Computer Specs are as follows:
CPU: Intel Core 2 Quad 2.66 GHz Q6700
Motherboard: Gigabyte GA-EP45 Extreme
Soundcard: M-Audio Audiophile 2496 + Line 6 UX8
OS: Win Vista SP1
RAM: 2GB (error free tested by memtest86)
PSU: Arctic Power 550 watt
This is a problem which has only started to occur but I can find no answers online and don't know what to do.. I have tried re installing the drivers and re installing the pod farm application but the problem is still happening even when the only program running is pod farm. The drivers are fine and detected by the computer when it turns on up until I load the PF program. When in podfarm and the drivers have crashed it still says "connected: Toneport UX8" but once the drivers are gone I cant open the line 6 audio and midi control panel device preferences and I can't open up the line 6 monkey program. The problem resets itself after I have restarted the computer and booted up again.
  • Line6Andy Line 6 4,345 posts since
    Jun 5, 2006
    Oct 20, 2009 2:15 PM (in response to crazycottydude)
    Re: POD Farm Crashes UX8 Hardware driver
    Hello,
      A couple things:
    1) have you updated the UX8 flash memory to 1.01?
    2) Have you tried a different computer system?  If so, are you experiencing the same error?  If you are not experiencing the same error, there is a problem with your system.  See the following links for possible remedies:
    Computer System Audio Optimization
    http://line6.com/community/docs/DOC-4201
  • Line6Hugo Line 6 6,580 posts since
    Apr 8, 2007
    Oct 21, 2009 11:56 AM (in response to crazycottydude)
            DO you have additional USB devices connected to your computer?
    Please make sure to disconnect all other USB devices from the computer (except for a mouse and keyboard) while troubleshooting this issue. Completely remove ANY USB hubs, even if not in use and test the UX8 on all of the USB ports on your computer.
    You should also make sure to test it on the other computer with the POD Farm application to see if it has the same issue. This will let you know if there is an issue with the UX8 hardware/software or your computer's USB ports.
    Regards,
    Line6Hugo
    • CptTripps Just Startin' 6 posts since
      Mar 4, 2008
      Oct 22, 2009 12:40 PM (in response to Line6Hugo)
      Just posted this under another thread but for what it's worth.  Gearbox did the same thing but not as often as podfarm.
      "I had this problem for months when I first picked up my Vista 64 rig, same thing with the lights coming on but still processing sound and seen by podfarm.  My PC has an i7920 and 9GB of ram so there was plenty of power and I patiently waited for driver updates.  In the end a $30 PCI-express USB addon card solved my problem.  It did not matter which onboard USB port I used it always crashed as soon as I hit record if not before.  Now, it tweaks once in a blue moon but is quite stable for the most part."
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
