Line 6 - Support
8776 Views 23 Replies Latest reply: Nov 21, 2009 5:23 PM by timowens RSS
philasonic Just Startin' 127 posts since
Oct 19, 2009
Oct 21, 2009 12:59 PM
Display has solid black bar on top line and shows Tone2 name below it.
I just updated my firmware to the latest version.  Fixed an issue where I couldn't toggle between Tone1 and Tone2.  But now I have new problems.
When editing, I've found that sometimes when I click stompbox (or engage the Wah, or mod, or delay) the Tone2 light turns off and the display shows black bar on top line and still shows Tone2 name.  So I see the name for Tone2, but it seems I might be actually in Tone1 (or neither).  Where the name for Tone1 would be, it's just all blacked out.
At that point engaging or disengaging any of the effects (stompbox/mod/delay) doesn't seem to do anything.  I have to either switch to another patch, or toggle Tone1/Tone2 back and forth to get back.
It's getting very frustrating when trying to edit patches because of this glitch.  It did not used to do this before the update.
It's also begun to change screens sometimes while I'm editing.  I read in another post a suggestion to move all pots and park them, which is good advice for minor corrosion and buildup on the pots.  But I didn't have this problem at all before the update, and now it's happening a lot.
I'm afraid that it seems I've traded one problem for two other problems.
Any help, or ideas, or ways to fix these problems?
Thanks in advance.
phil
  • timowens Gear Head 1,230 posts since
    May 14, 2007
    1) The "Display has solid black bar on top line" problem is a strange one. Did the update go smoothly? You might want to reinstall the firmware in safe mode.
    2) The display changing is both normal and abnormal. What I mean is that they added a feature so that whenever you turn one of the tone knobs it will bring up the edit window temporarily so that part is normal, if however it seems to come up by itself than that indicates a bad pot and that's where the advice to park the knobs comes in because there is a dead-zone at the minimum and maximum positions. Try it, turn one of the tone knobs and you'll see the edit screen come up, after about 2 seconds of no activity the previous screen should return.
    I've seen many strange problems get corrected by re-flashing the unit in safe mode so that's what I would try. Good luck.
        May 14, 2007
        Whenever they released that update that pops up the edit screen there was quite a few people who noticed it popping up all by itself but like you they never noticed and problems with the pots prior to that. Depending on where the pots are physically located and the settings of the pots stored in memory, the change in sound could be so subtle you wouldn’t notice it or very drastic so you would sense a boost or cut in volume. There were a few good ideas floating around about how to address this problem such as requiring a certain amount of movement before the system would register a change of the pots position but not much ever came of it. They did release an update that was supposed to address the “Digital Pot Jitter” but I don’t know if anyone ever noticed any difference. Be careful with contact cleaner, some of them on the market will absolutely destroy plastic, I work on two-way radios and we’ve had some products that if you spray it on a plastic housing, the plastic will simply crumble in your hands. Be sure to read the label very carefully. We currently use a product called LPS Electro Contact Cleaner and it has not given us any problems with plastic or rubber parts.
        As for the other problem, I just don’t know. I messed with mine trying to duplicate the problem but haven’t been able to. I was hoping someone else who has seen that problem would chime in. Again, I know a lot of goofy problems can occur if the memory or firmware gets corrupt, it’s happened to me a few times and the only thing you can do is re-flash it in safe mode, sometimes you even need to restore the factory settings and start all over again. This is especially true if you use GearBox to edit it, it is too easy to get GearBox and the POD out of sync by clicking buttons too fast or changing settings on the POD instead of the computer, I’ve whacked mine out quite a few times by doing that. Also, try to determine if it’s all presets or just one or two causing the problem.
  • Musterion Just Startin' 44 posts since
    Feb 6, 2007
    I recognize the problem and the jpg's!!!
    Haven't had a useful answer anywhere yet.
    It's NOT pots moving: going to -12 and +12 doesn't solve it.
    Been there, tried that.
    Has to be software, NO problems till software update!
    There's something very odd with the latest firmware.
    Not always, sometimes. In combination with Gearbox editing?
    Message was edited by: Musterion
  • Line6Hugo Line 6 6,332 posts since
    Apr 8, 2007
    Phil,
      I feel like another end user has brought this up once before.  Can you provide me with an exact recipe for reproducing the problem you are experiencing?  Include a detailed step by step recipe with what you are pressing to bring up the problem.
      Regards,
      Line6Hugo
        Apr 8, 2007
        I'll dig around for the old post, but also try to reproduce the issue because I know I saw this before.  I'll let you know what I find and post here.
        Regards,
        Line6Hugo
              Apr 8, 2007
              Phil,
              Here is the older thread that describes the recipe for the problem you have been experiencing:
              http://line6.com/community/thread/7003?tstart=0
              We were able to reproduce the issue using the recipe provided and logged a bug. We hope to see this resolved in a future firmware release.
              Does this answer your inquiry concerning the black bar issue?
              Regards,
              Line6Hugo
    Apr 8, 2007
    Phil,
      That is correct.  This issue (or similar issue) is a bug in the software code which a service center cannot repair.  We hope to have the reported bug fixed in a future update.
      But if you are experiencing the problem in a different manner, it is a different bug with the same result.  I have only been able to reproduce the problem that is detailed in the old posted thread.  In order for your specific issue to be addressed, we would need to find a reproducible recipe for that bug.
      Regards,
      Line6Hugo
    Apr 8, 2007
    As mentioned, we have acknowledged there is a bug using the recipe from the posted thread with the latest flash memory.  Fixing would require a new version of the flash to be created which is why a bug has been logged.  We hope to see this fixed in a future release.
      Regards,
      Line6Hugo
    Apr 8, 2007
    Hello,
      It's been a few days since we've heard from you. We're going to assume your question has been answered and close this thread. If you still have questions please feel free to open a new question with us and we will answer your questions accordingly. Thanks!
      Regards,
      Line6Hugo
    Apr 8, 2007
    Thanks for your feedback, but without being able to reproduce the problem, a bug cannot be written to fix the problem.  Any other additional info to HELP US recreate the problem YOU are experiencing (like the customer who provided the other recipe) would greatly help us in addressing the problem.  Without being able to recreate the issue, we do not know if this is a problem with just your X3 or not.  Are there any other end user's experiencing this problem in a manner different than the recipe that was previously provided?  If so, we need to be able to reproduce the problem, which we have been unable to do in any other manner than what was reported.
      Regards,
      Line6Hugo
    Apr 8, 2007
    Phil,
      We haven't heard from you here in a few days, so I going to assume that you were unable to reproduce the problem in any other manner.  We have also been unsuccessful in recreating the problem in a different manner.  I will go ahead and mark this question as assumed answered as a bug has been logged for the previous issue, but if you are able to reproduce the issue differently, feel free to reopen the thread or create a new question.
      Regards
      Line6Hugo
        May 14, 2007
        If you are confident that you can duplicate the problem on your unit within like 5 or 10 minutes then I would consider calling Line6 to see about sending it directly to them to check out. If they can duplicate the problem by following your instructions and they can’t fix it, I bet they would send you another unit. Whenever the X3 series was first released and there were so many problems with it, it wasn’t uncommon for Line6 to have people send their units back so they could see the problem first hand, and they would send a brand new unit to replace it.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
