Line 6 - Support
2550 Views 6 Replies Latest reply: Dec 23, 2011 10:52 PM by ritheremix RSS
japgold Just Startin' 1 posts since
May 2, 2007
Oct 21, 2009 4:13 PM
back track with no distortion?
when i record with the backtrack and put the files on my computer...i can't hear the distortion that i recorded the 'riffs' with....it's a clean guitar sound. my guitar goes into the input of the backtrack and the output to the amp. i can hear it on playback when plugged into the amp, but not in the computer. is this standard?
thanks
mike
  • MGrd Just Startin' 141 posts since
    Feb 29, 2008
    Oct 23, 2009 8:52 AM (in response to japgold)
    Re: back track with no distortion?
    The BT records what it gets. In your chain: the dry guitar signal only.
    If you want to record the distorted signal, you have to choose another setup, where the BT sits after the wet/distorted signal in your chain.
  • Line6Miller Line 6 11,613 posts since
    Mar 28, 2006
    Nov 3, 2009 2:42 PM (in response to japgold)
    RE: back track with no distortion?
    Hello,
      The above poster is correct. Any effects you want to hear in your recordings will have to go in line before the BackTrack.
      Does this answer your question?
      Line6Miller
    Mar 28, 2006
    Nov 5, 2009 9:18 AM (in response to japgold)
    Hello,
      It's been a couple of days since we've heard from you. We're going to assume your question has been answered and close this thread. If you still have questions please feel free to open a new question with us and we will answer your questions accordingly. Thanks!
      Line6Miller
    • ritheremix Just Startin' 6 posts since
      Dec 9, 2011
      Dec 23, 2011 9:57 AM (in response to Line6Miller)
      Re: RE: back track with no distortion?
      hello... can u show the diagram connection for this purpose.... i have the same problem when i want to hear my recording at the computer there is no distortion but sounded clean... i have try many connections...
      i have a pod hd 500 the output of the pod are being connected to fx loop return on my amp.
      input of the pod goes to my guitar...
      pod hd 500 output ---> amp fx return loop
      pod hd 500 input ----> guitar
      base on this connections where i suppose to connect the backtrack ?
      • silverhead Expert Line 6 User 7,250 posts since
        Apr 1, 2009
        Dec 23, 2011 10:57 AM (in response to ritheremix)
        Like MGrd says, the Backtrack will record the signal it receives at its input, and will not record anything that is further along in the chain. In your setup, you can place the Backtrack in several positions. Here is what will be recorded by the Backtrack in each case:
        1) Plug your guitar into the Backtrack Input, and plug the BackTrack Output into your Pod HD500:
        - the Backtrack will record the completely dry, unprocessed signal from your guitar.
        2) Plug your guitar into the Pod HD500 Input, plug the HD500 Output into your Backtrack Input, and plug your Backtrack Output into the amp FX Return
        - the Backtrack will record the signal leaving the Pod HD500. This signal will include whatever processing (amp/FX) you have applied within the HD500. It will not record any additional processing that your amp may be providing.
        3) Guitar -> HD500 -> Amp FX Return -> Amp Line Out (or mic'd amp) -> Backtrack input
        - the Backtrack will record the sound you are hearing from your amp, including all the processing that is being applied by both the HD500 and the amp. Note that if your amp does not have a Line Out jack, this option will require you to place a microphone in front of your amplifier's speaker cabinet and plug the mic into your Backtrack Input (or use the mic on the Backtrack+Mic product if that's the Backtrack model that you have).
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
