Line 6 - Support
3541 Views 5 Replies Latest reply: Nov 9, 2009 11:21 AM by Line6Perry RSS
Dante-the-Demon Just Startin' 4 posts since
Aug 3, 2008
Oct 29, 2009 6:52 AM
Problems with signals in and out
Hi
I've got two problems with my Gearbox software in stand-alone:
1) I can't hear anything from the metronome or player (even the tutorial track) but my signal from amps is OK. However I use Gearbox 3.70 and all the latest updates are installed on my PC.
2) The sound tends to be oversaturated. I can hear it because the distortion presets crush regularly (the problem doesn't come from my instrument or my USB cable or my audio monitors, I verified all that before). Is it normal that the Monitor Clip/Light and the Output Indicator/Clip Light become yellow when I play any note, even very softly, even when both the volume knob and monitor volume are nearly minimum?
Thanks and regards,
Vince
  • Rowbi Expert Line 6 User 7,450 posts since
    Nov 25, 2006
    Oct 30, 2009 5:13 AM (in response to Dante-the-Demon)
    Re: Problems with signals in and out
    can you explain how you've got everything connected to your device (what device are you using?)
    on point 2, have you tried editing the patches?  the default ones are only meant to be a rough guide and may not work for all peoples with all setups, as you may be using active pickups with a patch that's setup for a guiter with single coils, so you're adding a load of gain to boost pickups that isn't needed.  obviously that may not be the case, but that's just a guess.
  • Line6Perry Line 6 Support 6,652 posts since
    Dec 26, 2007
    Oct 30, 2009 1:39 PM (in response to Dante-the-Demon)
    RE: Problems with signals in and out
      +1 to Rowbi's suggestions. Please let us know if they helped answer your question!
      Regards,
      L6Perry
    Dec 26, 2007
    Nov 3, 2009 11:18 AM (in response to Dante-the-Demon)
      I'm not 100% sure about what you're experiencing. Can you try something for me?
      Do not run GearBox software. If your Vista audio settings are set to use the UX1 as your default audio I/O, run iTunes and play a track back.
      Then, as the song is playing launch GearBox software. Start playing guitar.
      Was there a change in gain/volume/distortion at the output? Your iTunes volume setting should be independent of GearBox volume settings. Please let us know.
      Regards,
      L6Perry
    Dec 26, 2007
    Nov 9, 2009 11:21 AM (in response to Dante-the-Demon)
      It's been a couple of days since we've heard from you. We're going to assume your question has been answered and close this thread.
      If you still have questions please feel free to open a new question with us and we will answer your questions accordingly. Thanks!
      Regards,
      L6Perry
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
