Oct 31, 2009 12:44 PM
Using 2 amps
Like (0)
I would like to know if can connect theJM4 "out to amp" output to a nice guitar amp and the "stereo out" outputs to a keyboard amp? I am sure I can do this but this is the real question..I want a processed guitar signal to go to the guitar amp and all of the other recorded stuff(backing tracks, drum grooves, etc) to go to the keyboard amp...Of course, the reason being is that I want to hear my guitar thru my tube amp and the other stuff thru a wider frequency range of a keyboard amp..thanks..
The Output Routing setting under the SETTINGS/TONE menu can be set to Performance to send only the backing tracks to the stereo outputs without the Guitar. This should do what you want.
Thanks for the help..I think I knew that but will the guitar/amp out signal be processed with the JM4 effects? If not, is there a way to get them processed with the JM4 and then have them routed to my other amp? I know about some of the switchers available but was hoping to keep it simple...Also, will the guitar out to amp signal be able to be looped? thanks a ton..
The guitar amp output will have eveything you expect from the JM4 except the backing tracks which go to the other amp.
Hey Joe..thanks so much for taking time to help me out. Obviously I haven't bought the looper yet and this is why I have these questions..Finally, will the guitar out signal have just the looped and processed guitar part of the loop I create and not the backing, preloaded stuff? I am sure you can see where I am going with this..thanks
I would suggest that you go up to the ::Support Menu above, choose Product manuals, go to Stompbox Modelers and download the JM4 manual and advanced manual. These will show you all the possibilities.
