2205 Views 1 Reply Latest reply: Nov 6, 2009 8:34 AM by joegillespie RSS
steveguttman Just Startin' 8 posts since
Aug 1, 2009
Nov 6, 2009 4:22 AM
Hiss problem with new Spider Jam
Hi
Not sure if this is a problem, but something doesn't seem right. When I have the volume cranked up around level 4 or 5 I get a hiss sound from the amp. The problem seems to be directly related to the mic input. When I turn the mic trim nob up the hiss gets worse. Even with the mic trim nob turned all the way down and the mic input level set to off, i still hear the hiss starting around level 5 of the master volume. As a note, if I plug in the headphones I don't hear any hiss.
Thanks
steve
  • joegillespie Gear Head 795 posts since
    Mar 31, 2007
    Nov 6, 2009 8:34 AM (in response to steveguttman)
    Re: Hiss problem with new Spider Jam
    You need to turn down the MIC input level. Press INPUT/LEVEL button twice. MIC should be selected and the LCD reading shows something between -60 and +20 dB. Use the large silver knob to wid the MIC input level down to about -10 dB and the hiss should go. Keep the MIC sensitivity down to about half way, or off completely of you are not using a mic.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
