Line 6 - Support
1331 Views 1 Reply Latest reply: Nov 10, 2009 5:29 PM by silverhead RSS
llama11 Just Startin' 1 posts since
Nov 10, 2009
Nov 10, 2009 6:38 AM
Backtrack for Harmonica player - will it work?
Hi
Im a harmonica player - i just need a good recorder for recoridng ideas/song etc. I play into a shure sm58 - akai headrush- roland cube amp - audio out - "recorder" -
will the backtrack work recording out of my amp 6.35 mm jack out?
if not any ideas what will work
cheers
  • silverhead Expert Line 6 User 7,250 posts since
    Apr 1, 2009
    Nov 10, 2009 5:29 PM (in response to llama11)
    Re: Backtrack for Harmonica player - will it work?
    I expect so - the backtrack will record any signal it receives at the 1/4" input jack.I presume you're using some effects on the amp (other than simply volume) to affect tone? If not, you might be able to go directly from your akai to the BackTrack.
    If using the amp you may have to fiddle with levels because the amp out is likely line level and the backtrack input is likely instrument level. If your amp has an instrument level output it might work better. Also you will need an adapter from your amp out to feed the BackTrack 1/4" input.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
