Line 6 - Support
2668 Views 8 Replies Latest reply: Nov 23, 2009 1:35 PM by Line6Perry RSS
koolaide Just Startin' 6 posts since
Nov 13, 2009
Nov 20, 2009 12:51 PM
TonePort DI-S No Sound
I just received my TonePort DI-S from my GuitarPort bundle.  I installed all of the software.  I have the TonePort plugged in.  I have a green light.  I have re-installed drives more than once.  I have restarted the computer more than once.  I have switched USB port, computer front panel not a hub.  I have all of the up to date Drivers, USB, Gear Box, etc.
I am getting no sound through my computer speakers from the Guitar.  I see needles moving on Gear Box.  I have twisted knobs, pushed buttons, tried combinations of things.  I can hear the video tutorials played from the embedded browser at the bottom of gear box just fine.
I know there is something super simple that I am not seeing here.  Why can't I hear my guitar played through my PC speakers?
thanks
koolaide
  • Rowbi Expert Line 6 User 7,450 posts since
    Nov 25, 2006
    Nov 20, 2009 1:04 PM (in response to koolaide)
    Re: TonePort DI-S No Sound
    are you computer speakers plugged into your cmputers built in sound card (which isn't being used when the toneport is connected, as the toneport becomes your sound card).
    so connect your speakers to the toneport.
  • Line6Miller Line 6 11,613 posts since
    Mar 28, 2006
    Nov 23, 2009 12:37 PM (in response to koolaide)
    RE: TonePort DI-S No Sound
    Hello,
      you are over complicating things.
      If you want to leave your speakers connected to your computer here is what you need to do.
      1. Buy a 1/4" to to 1/8" in Y cable. The 1/4" side should have 2 mono leads and the 1/8" side should have one stereo lead.
      2. Run the 1/4" sides out of the left/right analog outs on the TonePort.
      3. Plug the 1/8" stereo side to the Line In on your computer (this will be located near your speaker out)
      4. Go to your Windows Control Panel and look under sounds and audio devices. Under the audio tab, set the TonePort to be your main input and output device.
      Please see the following video tutorial for more info on this.
      http://line6.com/community/docs/DOC-1427
      Please let me know if this answer has been helpful.
      Line6Miller
  • Line6Perry Line 6 Support 6,642 posts since
    Dec 26, 2007
    Nov 23, 2009 1:35 PM (in response to koolaide)
      That is most likely because you purchased a stereo 1/4" to 1/8" adapter. But the issue is: one of the Analog Outs (1 or 2) is not stereo, it's a mono output. Therefore, you're only going to ever get a one-sided output into a stereo speaker cable connect point.
      This is what you'll need: http://accessories.musiciansfriend.com/product/Monster-Cable-MCL-MSTMINI-2FM-18-Stereo-Male-to-2-4-Mono-Female-Cable-Adapter?sku=330059&src=3WFRWXX&ZYXSEM=0&CAWELAID=43140940
      Then, you can connect 2 little 1/4" mono patch cables to the Analog Outs 1/2 (Left/Right). You should then hear full stereo output at your speakers.
      Regards,
      L6Perry
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
