Line 6 - Support
2039 Views 12 Replies Latest reply: Nov 22, 2009 11:38 AM by camshaft35 RSS
camshaft35 Just Startin' 14 posts since
Oct 22, 2009
Nov 21, 2009 3:03 AM
..regarding x3 live effects loop..
..i've got 2 tonebone pedals with high gain settings in the loop , configured 'pre' , and yet to get enough level , the return is at +20db -
   the amp block is off , and i've got the eq set with mid cuts , to try and get the cleanest sound , going into the fx return of a marshall avt combo..
       this works ok , but if i try to switch the amp block on , the levels all are way too low -
         if i put the loop 'post' , then the comp/boost doesn't have nearly the desired effect..
           i must be doing something wrong..
             also there's alot of noise when the pedals are on - the gate seems to have little effect - shouldn't it be at the end of the chain?
              lastly , the momentary display feature for the amp tone controls doesn't seem to be working at all , minor gripe , but still ??
                   any advice appreciated , thanx , cam..
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
