Dec 25, 2009 9:59 AM
jam file conversion to wav format
Like (0)
when i pass my loops from the amp (spider jam) to the SD card and to my computer all the files where in a format called JAM and i cant play any of them, how can i convert them to WAV format?
Many thanks
robert
If you look down the menu you will find a wave conversion on the amp its below the jam conversion use that ![]()
Save/scroll down to "Save Rec Mix As Wav To Card"/right-arrow.
This will save the recording you select as a 16-Bit MONO 44.1K .wav file onto the SD card.
Regards,
L6Perry
when ever i go to the "save rec mix as wav to card" it says SD-CARD write error. im using a 2GB sandisk sd card if that makes a diferance... please help <3
you need to format your sd card
