5732 Views 6 Replies Latest reply: Jan 1, 2013 7:52 AM by phil_m RSS
Anothe Just Startin' 5 posts since
Dec 22, 2009
Jan 10, 2010 8:52 AM
Output level too low on Pod 2.0
Trying to record from Pod 2.0 to simple laptop with built in soundcard.  I know this is not an amazing soundcard.
Getting waay too much hiss.  This is not EMF buzz, but the Pod's hiss and it is very loud.
I followed the advice on one of the FAQs on this site and got a 2xquarter inch mono to 1xeighth inch stereo Y cable.  Connected the 2 mono sides to the Pod 2.0 TRS outs, and the eight inch side to the line in of the soundcard.  Signal was in stereo and left and right were good but it was too low compared with the loud hiss coming from the pod 2.0.  Then tried just going from the left TRS into the soundcard using a mono instrument cable with a quarter to eighth adapter.  Same problem with loud hiss.
As a workaround I am now recording from the mic out of the pod 2.0 into the line in of the soundcard.  This gets the signal loud enough to cover the hiss and is acceptable I guess.  But I figure this is not the "right" way to do it.
Any suggestions please on how to use the TRS outs and still get the signal high enough?
Settings -
The DI/AIR was set to DI
Output and channel both set to 10 like the manual said to do for best sound and lowest noise
Tried different amp presets
Thank you in advance.
    • ITD09 Just Startin' 7 posts since
      Jul 16, 2009
      Jan 22, 2010 6:39 AM (in response to Anothe)
      Re: Output level too low on Pod 2.0
      I just posted the same sort of question. But I'm going from the POD to a dirt cheap Behringer Audio Interface, but when I go to record the output level coming through is pretty weak so I have to boost the output level which then distorts when I try to record. Hopefully we'll get a couple suggestions that'll help solve the problem.
  • ercatto Just Startin' 2 posts since
    Jun 23, 2010
    Aug 21, 2010 12:14 AM (in response to Anothe)
    sorry for the delayed reply, but this is the first time i visit the community...
    1. I've same problem. If you want good result use a GOOD external soundcard
    2. Try to use the internal noise gate (see below)
    possible solutions:
    1. cable is too cheap: low quality cable = low quality sound
    2. try to set your line input level. you can do that with a recording software able to monitor input level.
    3. don't use mono cable into a stereo input.
    4. Again Use internal noise gate (see below)
    I don't know if this the right way, 'cos my POD 2.0 don't have mic outs!!!
    my POD just have Left and Right outputs.Where are my mic outs?
    http://it.line6.com/pod20/images/ins01.jpg
    Try these:
    • Use your Y cable, connect Left and Right Pod outputs to your PC line input;
    • A.I.R. Mode on DIRECT!
    • start a recording software, monitor your line input
    • try to get the right "balance" from the POD's output level and the PC's input level. You must never go Over 0dB!
    • Some POD amps are very noisy, that's normal. POD have an internal noise gate. try to push the related button. if you want, you can try to set the right noise gate's level. you can do that via "Line6 Edit" or via MIDI if you want (read the manual).
    when i practice with backtracks and i don' need big quality i use POD directly connected to PC.
    when i need to rec i don't use a DI box between POD and PC. I instead use a better soundcard (M-Audio Firewire 1814), with high quality cables.
    hope this help.
    P.S. Sorry for bad English.
    Max
  • phil_m Expert Line 6 User 4,243 posts since
    Jan 25, 2007
    Jan 1, 2013 7:52 AM (in response to Anothe)
    The hiss is due to the fact that laptop soundcards are universally horrible, especially the 1/8" in. They're designed to be used with a microphone, so they have a cheap preamp in the circuit. That's why you're getting so much hiss.
    The 1/4" outs on the POD line level and balanced, and they should be relatively quiet. I've recorded almost a whole album using a POD 2.0, and noise was never an issue. Actually, I'm surprised you seem to be having an issue with not having enough level. You should have plenty of level coming from the 1/4" outs.
