13207 Views 30 Replies Latest reply: Jun 13, 2012 12:51 AM by andykojezz RSS
bwhokirk Just Startin' 19 posts since
Feb 22, 2009
Mar 24, 2009 6:58 PM
Bass PodXT Midi Timeout
Well I finally figured out my first problem, that was caused by having the device plugged into a hub.
So on to my second problem, again everything has been updated and computer meets specifications.Picture 1.pngPicture 2.png
Now, everything is showing that the connections are good, and the pod shows up when I start Line 6 Edit, but when the Tone Locker tries to connect I am getting a midi timeout. At the same time the process bar is showing it trying to connect the display on the pod fade in and out not completely out just dim a little.
I also received the following message;
MIDI Timeout while requesting manual mode patch
cmn.l6java.patch.L6PatchManager$DeviceNotConnectedException: null
App info: Line 6 Edit 3.01 release - build 99 - Fri Oct 27 14:49:03 PDT 2006
Date: 3/24/09 7:15 PM
In thread: L6Thread - 'L6MIDIJava dispatch thread' - started at cmn.l6java.midi.L6MIDIJava.L6MIDIJava.Start - line 206
OS: Mac OS X (10.5.6 i386)
Java VM Version: 1.5.0_16
Stack trace:
at cmn.l6java.patch.L6PatchManager.AcquireDevice(L6PatchManager.java:658)
at cmn.l6java.patch.L6PatchManager.RequestDeviceEditBuffer_Sync(L6PatchManager.java:717)
at cmn.l6java.patch.L6PatchManager.RequestEditBuffer(L6PatchManager.java:391)
at line6editbase.editor.L6Editor.SetCurrentPatch(L6Editor.java:673)
at line6editbase.editor.L6Editor.SetCurrentPatch(L6Editor.java:601)
at line6editbase.editor.L6Editor.OnMIDIPatchChange(L6Editor.java:932)
at cmn.l6java.patch.L6PatchManager.NotifyListenersOfPatchChange(L6PatchManager.java:886)
at modules.sharctone.device.L6SharcTonePatchManager.OnPC(L6SharcTonePatchManager.java:133)
at cmn.l6java.midi.L6MIDIManager.OnPC(L6MIDIManager.java:626)
at cmn.l6java.midi.L6MIDIManager.HandleTrackedPC(L6MIDIManager.java:307)
at cmn.l6java.midi.L6MIDIManager.OnMIDIEvent(L6MIDIManager.java:173)
at cmn.l6java.midi.L6MIDIJava.L6MIDIJava.DispatchMIDIData(L6MIDIJava.java:550)
at cmn.l6java.midi.L6MIDIJava.L6MIDIJava.Run(L6MIDIJava.java:612)
at cmn.l6java.core.L6Thread.run(L6Thread.java:158)
  • willdaley Just Startin' 13 posts since
    Mar 28, 2009
    Mar 29, 2009 9:18 AM (in response to bwhokirk)
    Re: Bass PodXT Midi Timeout
    Having the same problem. What is the solution?
        Mar 28, 2009
        Mar 29, 2009 11:55 AM (in response to bwhokirk)
        That's not good. I haven't asked to exchange the pod -- I think the USB connection is working, it seems to recognize the device, so it's some failure with the software. I'm using Vista, you're on Mac, and it's the same basic issue, so it seems odd that it would fail in the same way in two different operating systems. Would appreciate any info you're able to gather.
        Here's a link to a separate thread I've started.http://line6.com/community/message/10911#10911
              Mar 28, 2009
              Mar 30, 2009 11:10 AM (in response to bwhokirk)
              Hey, thanks a lot for letting me know. How very strange. I've found a few others on different forums with similar sounding problems, but not seen an answer on any thread.  I wonder... I modified and saved one of the factory pre-sets before trying to go online to connect. I'm wondering if there's a bug where the pod must be unaltered before connecting for the first time. It's just got to be the software, but it's so strange that it's happening under such different circumstances.
                  Mar 28, 2009
                  Apr 4, 2009 11:34 AM (in response to bwhokirk)
                  Not sure if you've resolved this yet, but I've written the Vice President of Customer Service to see if she can't help us find some solution to the issue. I've sent her links to this and my original thread, so hopefully we'll hear back soon. Here's the email I sent:
                  I purchased the Bass Pod XT Live about a week ago. I think it's a great product, but I have been unable to access the online functionality due to a "MIDI timeout" error when trying to connect to the tone locker. When I posted my issue on your support forum I found that there are others having the problem, with unfortunately no resolution to it despite efforts to contact customer support. I, and I'm certain the others on the threads below, would greatly appreciate a solution to the problem.
                  http://line6.com/community/message/10735#10735
                  http://line6.com/community/message/12275#12275
                • bassistedan Just Startin' 6 posts since
                  Aug 1, 2009
                  Aug 2, 2009 12:06 AM (in response to bwhokirk)
                  Same thing happen to me, I bought my POD brand new, & I also try using a different OS (Mac Tiger & Windows XP) with the line 6 editor but still get the same bloody msg...ergh!!!!!!
                    • edvon Just Startin' 1 posts since
                      Aug 2, 2008
                      Sep 2, 2009 2:31 AM (in response to bwhokirk)
                      yep, same problem here. Mac OSX10.5.7 Monkey got all the latest updates, tried all USB ports and 4 different cables. line 6 edit will not work...
                      This is very frustrating.
                      I haven't tried a different OS and computer yet, but from what I've read here it might be a lot of work for no positive outcome anyway...
            • toneman2121 Gear Head 1,985 posts since
              Oct 15, 2006
              Mar 30, 2009 11:16 AM (in response to bwhokirk)
              u da man! seriously your patience and persistence has come through
  • Disraeli Just Startin' 3 posts since
    Dec 13, 2007
    Mar 31, 2009 6:53 PM (in response to bwhokirk)
    I to am having this problem ...after running monkey and updating the driver and something else, then all of a sudden line 6 edit gives the midi timeout error message when trying to connect to the bass podxt. I have the regular guitar podxt as well and am able to connect just fine with that. I have tried going back the the previous version of the driver and line 6 edit as well as reflashing the firmware... still no workie! I hope they get this figured out soon cause this is really bugging me. They should also not allow Monkey to update this stuff untill they get it fixed!!!!!!!!!! My 2 cents
  • mariomeijers Just Startin' 9 posts since
    Mar 31, 2009
    Apr 7, 2009 12:07 AM (in response to bwhokirk)
    Hello there,
    I bought my BassPod xt a week ago and have the same problems on my pc (windows xp). When I use monkey and do the check evrything is OK but starting up edtit my pod is recognized but after completely starting up I get the message  MIDI TIME_OUT.
    I'm looking for help...
    gr mario
  • subspecies Just Startin' 1 posts since
    Dec 27, 2007
    Apr 18, 2009 7:49 PM (in response to bwhokirk)
    so is there anyway to fix this problem yet . . mine just started the midi time out error a couple days ago ..  and i have been going crazy  sense . . please  help .. ..
        Mar 31, 2009
        Apr 20, 2009 9:41 AM (in response to bwhokirk)
        I was glad I could change my pod 3 times at the local store but all these 3 had the same problems on 4 different pc I could try it on. At least I was happy that I could change my pod for a boss me50B at my local store.
        wishing you all the  luck
        gr mario
  • rockastle Just Startin' 3 posts since
    Mar 14, 2007
    Jun 3, 2009 7:44 AM (in response to bwhokirk)
    Same thing here. I'm trying to sync a Bass POD XT with Edit and I get the MIDI time out error. It's not the cable, the USB port or anything else on my computer (I also tryed a different one) as I can sync my XT Live and X3 Live perfectly. I've reset the Bass POD to factory settings, changed driver versions, updated everything I could and later went back to the previous version and still get the same. By reading previous posts I can tell it's a problem with the POD, or Edit not being able to read it. Would be nice to have a word from Line6 tech support.
      • wpugh949 Just Startin' 6 posts since
        Jun 30, 2009
        Jun 30, 2009 11:41 PM (in response to bwhokirk)
        BUMP!!!
        I just posted in another thread on this already but this is the thread I belong to because whalllaaa I am having the same issue.
        For the tech to say your settings are wrong that's that is a real shame. They should post a "how to" change your settings to get it to work or in the very least admit they don't know what the issue is and say they are working on a solution with an eta.
        I am running Vista...I have all the latest downloads and I am having the exact same connection issue.
        HELP PLEASE!!
  • lordoflow Just Startin' 12 posts since
    Feb 26, 2007
    Jul 14, 2009 9:56 PM (in response to bwhokirk)
    Same here, I've reflash installed and reinstalled everything and still the same midi time-out. I would love to edit on the pc. My guitar podxt runs "edit" perfectly. I'm thinking some thing in the bass podxt driver or flash memory. When was the last time they even up dated the flash. Bassist get no respect....
    BTW I love my pods. Had them for 4 years with no problems but this.
      Mar 28, 2009
      Jul 15, 2009 4:58 AM (in response to lordoflow)
      I had this problem with my Bass Pod (I had posted earlier in this thread). I went back to the store and exchanged. The new one worked perfectly. But it seemed really strange since my computer was definitely recognizing the Pod through USB - it just wasn't connecting to the editor. In any event, problem solved, so I went on with my life. Then, a month ago, I got a Korg M50-88 workstation. Lo and behold, when I went to connect to that machines editor through USB it was the same basic problem. My machine clearly knew the M50 was connected, but it would not recognize it in the editor.
      So, I called Korg customer service and in two calls I got their software support on the line who explained that there is a 10 MIDI device limit in Windows Registry. So, he took me into the registry, had me clear out a couple unused MIDI entries and - presto- my M50 now connects fine.
      Here's the thread that I started on the Korg forum with an answer down the line:
      http://www.korgforums.com/forum/phpBB2/viewtopic.php?t=44465
      This doesn't explain why my Bass Pod worked after I exchanged it, since I really don't think it was a hardware problem at all.
      It also doesn't explain why I couldn't get an answer from Line 6. I wrote emails to Line 6 customer service with no response. Others on this thread called them to no avail. Line 6 has great stuff, but no one likes a primadona.
      Anyway, I hope this answer solves the problem for those of you still experiencing it.
      -Will
    Feb 26, 2007
    Jul 18, 2009 7:41 AM (in response to bwhokirk)
    I finally got edit to work. I uninstalled all line 6 programs and drivers, then went through the whole pc to clean up any remaining fragments left in program files and user files. Then a local search to find anything else. Then reinstalled monkey, drivers, then edit. I still can't see flash updates on monkey but edit is working fine. Also, make sure you have the correct version of Java running, ver. 5 update 11. I got rid of all other versions and turned off java updates.
    Hope this helps, JD
  • muskarver Just Startin' 1 posts since
    Aug 4, 2009
    Sep 12, 2009 11:32 AM (in response to bwhokirk)
    hi friends sorry for my bad english..
    I had same problem but ı soved it.
    ı have pod2.o and win xp with sp3.
    In Windows XP ( My xp in turkish so ıdont know exact terms of english in windows) go to control panel and select sound setting and chose youre midi output device as picture attachments:
  • andykojezz Just Startin' 3 posts since
    Jan 20, 2012
    Jun 13, 2012 12:51 AM (in response to bwhokirk)
    SOLUTION:
    I had the same problem. This is what helped:
    1) Use LIne 6 Monkey to reinstall USB firmware and FLASH memory (this order).
    2) Then use Line 6 uninstall utility to remove DRIVER and EDIT program.
    3) Last step is factory reset of POD.
    Restart computer and install DRIVER and EDIT program again without Java runtime (it worked for me).
    IMPORTANT: Do not change any setting nor preset in POD before first succesfull connection with Edit program!!! Better do not even touch it.
    It could be the reason of  midi timeout issue.
