5295 Views 7 Replies Latest reply: Nov 21, 2012 7:40 AM by district6 RSS
thuss73 Just Startin' 1 posts since
Feb 5, 2007
Mar 26, 2009 2:07 PM
DL4, powers up, no sound
I have a DL4 that powers up with tap LED flashing and all but no sound, wet or dry.  It passes a signal in bypass.  I've check out the jacks, and even swapped relays.  And of course, I did the re-boot too.  Ideas?
  • elwood55 Just Startin' 1 posts since
    Mar 30, 2009
    Mar 30, 2009 7:35 AM (in response to thuss73)
    Re: DL4, powers up, no sound
    I have the same exact problem, and word yet on a solution?
    thanks,
    todd
    • smokingskunk Just Startin' 4 posts since
      Oct 15, 2007
      Jun 10, 2009 7:37 AM (in response to elwood55)
      my dl4 still lights up .when bypassed it gives me sound however when i switch one of my presets on i get no sound. i only get sound when the unit is bypassed.
      I did the reset thing to factroy default did the true bypass reset changed cables everything but am having no luck
      line 6 help me please
  • Line6Sach Gear Head 1,351 posts since
    Oct 31, 2008
    Jun 19, 2009 8:24 AM (in response to thuss73)
    HI guys,
    First, please do register your DL4s on your account. Having the SN can aid in troubleshooting, if nothing else so that we can easily find out what you have to work with.
    In terms of your question, please remember that while this is a support forum, you must mark threads as a question to be sure a Line 6 Rep sees it immediately. If not, the intent is that the community will be able to assist you as well, but you may not get the direct support you are hoping for.
    If you are still having problems, please register the device here: http://www.line6.com/account/registergear/. Then let us know exactly how you have the DL4 plugged into your signal chain, how it is being powered and what troubleshooting you have done to this point.
    Thanks
    Line6Sach
    • lafave Just Startin' 1 posts since
      Sep 10, 2009
      Sep 10, 2009 3:41 AM (in response to Line6Sach)
      Hello Sach,
      I've registered my DL4 after reading this thread. Got exactly the same problem with mine. Haven't used it in a while. Have tried the factory reset already with the A-D switches. The leds are blinking when inserting the instrument cable. After that it's silent. In the beginning I heard nothing at all. But now I get the true bypass sound and can't get the effects to work. Switching with the footswitches doesn't work either. I tried turning all the knobs and a couple of factory resets. Power supply is a Line 6 MKA-091200GS, output 9V 1200mA. I read in another thread about 2000mA, maybe that has became the standard later? I own the box since 2001.
      I hope there are some actions I can undertake myself in order to get the box working and am looking forward to your reply.
      Greetings,
      Ype Reitsma
    • brunnocruz Just Startin' 1 posts since
      Oct 5, 2011
      Oct 5, 2011 12:26 PM (in response to Line6Sach)
      Hey Guys!
      I just got my dl4 and I have the exac same problem!
      I'm so frustrated, because I'm Brazilian and I bought the line 6 in America, so I checked this failure only when I got my country.
      Someone could fix that?
      Greetings.
      Brunno
  • sstevko Just Startin' 1 posts since
    Jan 28, 2012
    Jul 9, 2012 2:10 PM (in response to thuss73)
    I have the same issue... DL4 powers up but without any sound.. works just bypassed.
    I tried to cool the unit down in a refrigerator for about an hour and it started to work again. Then again it stopped after few hours. I tried this procedure several times and it worked.. seems like something is overheating inside.
    • district6 Just Startin' 1 posts since
      May 19, 2011
      Nov 21, 2012 7:40 AM (in response to sstevko)
      Guys I have the DL4 - had that same issue - get registered then search repair places for your area - apparently there is a power surge thing or something - they all do it eventually - or sooner than later - mine took 5 yrs - once fixed worked like a charm - was about $75 -$80 bucks - 2 weeks - ona another note - whenit was gone - my tone was horribal - the thing is magic - get it fixed - ps I have the M9 and they are NOT the same.
