1 ... 68 69 70 71 72 73 Previous Next 55412 Views 1,087 Replies Latest reply: Jul 1, 2011 6:01 PM by jcianchetta RSS Go to original post
  • Magiamusical Just Startin' 17 posts since
    Nov 23, 2007
    1,035. Oct 18, 2010 7:44 AM (in response to Line6Angela)
    Re: Welcome to the James Tyler Variax group!
    One thing I would like to see is some sort of a footswitch controller  without modeling nor effects  that could change the patches to Variax guitar instead of using the on-guitar controls. That would make changing the type of guitars easy accesible and fast switching within a song.
    Variax Guitar ------------->foot controller------------->amp
  • grimm26 Just Startin' 303 posts since
    Nov 13, 2007
    1,036. Oct 18, 2010 7:54 AM (in response to Magiamusical)
    They have one.  It's called a POD HD500 .  Just set the amp model to empty and don't enable any effects.  Your box would have to talk VDI and be able to store variax model information, have a display and several buttons, and spit out analog guitar tone on a 1/4" jack out the other end.  You may as well get a POD.
    Nov 23, 2007
    1,037. Oct 18, 2010 10:39 AM (in response to grimm26)
    That's an expensive solution considering that the only functionality that I would like is remote Variax switching. Anyway Its was only a wish.
    Thanks for the response.
  • RogerZ Just Startin' 34 posts since
    Jul 7, 2007
    1,038. Oct 18, 2010 12:39 PM (in response to Magiamusical)
    It is also possible with POD XT Live an POD X3Live, less expensive!
    Nov 23, 2007
    1,039. Oct 18, 2010 1:26 PM (in response to RogerZ)
    I do own a Pod XT Live but it is big and with my pedalboard it takes a lot of real state. My wish was more of a simple Variax remote control.
    Does Line 6 provides the protocol used to comunicate with the Variax?
    Is it std Midi control?
    Nov 13, 2007
    1,040. Oct 18, 2010 1:30 PM (in response to Magiamusical)
    If it were MIDI they'd use a MIDI cable .  they use a cat5 twisted pair with RJ45 connectors (4 pairs of wires twisted together with 8 conductor connectors), same that is used for ethernet.  I have no idea what kind of signalling they do.
  • variaxlover Just Startin' 323 posts since
    May 19, 2007
    1,041. Oct 18, 2010 1:45 PM (in response to Magiamusical)
    I hope no one minds me sharing this information . . .
    Variax control via MIDI:
    Nov 13, 2007
    1,042. Oct 18, 2010 1:49 PM (in response to variaxlover)
    ok, so how do I plug in a MIDI cable to a variax?  What's the missing link?
  • WSheehey Just Startin' 54 posts since
    Dec 20, 2007
    1,043. Oct 18, 2010 4:04 PM (in response to grimm26)
    Dec 20, 2007
    1,044. Oct 18, 2010 4:10 PM (in response to WSheehey)
    The above diagrams are from Vettaville.  I used the Variax wirelessly for a long time by modding the ethernet cable to MIDI on both ends of a wireless MIDI transmitter (in conjunction with a guitar wireless unit).  I'd guess that knowing the connections, you'd be able to use a foot controller the same way.
    Nov 23, 2007
    1,045. Oct 18, 2010 4:11 PM (in response to WSheehey)
    Thanks for the informaion, I have seen parts of this information before but not as clear as here.
    Again thanks
    btw: I will get one of the Tyler Variax when available.
  • toasterdude Just Startin' 745 posts since
    Oct 23, 2006
    1,046. Oct 18, 2010 7:58 PM (in response to WSheehey)
    I assume you used the vax with a vetta? I never could figure out if that same setup would have worked with a POD x3. I sure hope they atleast add that capability to HD500. If they are targeting working pros with JTV . . . a good many of them require wireless. of course now that we can have both mags and models we would have to lose that feature if we wanted wireless.
    I REALLY want a wireless that brings both mags and models from vax to POD and sends program change from POD to variax. Not only should it work with POD but should have a midi in so a touring guy can send vax program changes with a GC pro or similar of he doesn't use the POD.
  • OZLO Just Startin' 38 posts since
    Oct 10, 2007
    1,047. Oct 19, 2010 4:09 AM (in response to toasterdude)
    As far as I read this selfmade wireless system depends on an update for the Vetta that makes it send MIDI controles even if it does not recognize a directly connected Variax. This has never been brought down to the PODs, so this wireless workaround is limited to the Vetta
    Correct me if this has changed. I also hope we will see a wireless VDI in the future as this selfmade solution shows that is is possible so the only thing missing is taking also the audio and maybe power from the VDI and integrate this workaround into a single box. I would have loved to see this integrated into the coming James Tyler Variax and POD HD, it would have been amazing to play your guitar and POD without having to connect anything. But those at Line 6 will have their reasons and so I hope for the future.
    Dec 20, 2007
    1,048. Oct 19, 2010 5:55 AM (in response to OZLO)
    Yes, I was using it with a Vetta II HD.  I sold that head, because I won't need the Variax to send MIDI info any longer.  The JTV will solve all of my problems.  I (will) now be able to get the best tone possible with my Axe FX Ultra and not have to sacrifice tunings.  That was my primary use for the Variax wireless set up - even though it was bulky and a battery hog (6 AAs in the guitar and a D in the MIDI transmitter all together on my strap or belt) - I needed the full bank of models in standard and more than the 10 custom spots for alt tunings.  I have no issue changing the tone knob on the guitar between songs.  Now that I can play any model and switch the tunings quickly - I'm fine.  We don't play any songs that require that I change models or tunings during the song.  And with the long lasting battery (I'll buy a 2nd one as soon as I can), I'll be in heaven.  I have the Line 6 wireless - which has never let me down - and I'm going to use the MIDIJet Pro to send info from my MFC-101 MIDI foot controller.  I'm using a POD X3 Pro as my Variax interface now (I don't think I ever owned a dedicated interface - it was always plugged into another Line 6 product), and it's great that I can get rid of that and will get an interface for Workbench with the new guitar.  If anyone's interested in buying the X3 Pro, let me know.  I'm sure I'm the only person who feels this way, but I really can hardly wait for that guitar!
    Oct 10, 2007
    1,049. Oct 26, 2010 1:41 PM (in response to Line6Angela)
    Hi!
    I was just looking for some custom shop stuff for that personal touch of my next variax. I am interested in a graphical truss rod cover but to go for it I need a drawing with measurements of the one on the JTV 59. Of course I could wait for the guitar and do this myself but I'd like to have things together  when the instrument arrives, so can someone help me with this?
    Thanks a lot.
Actions
