3057 Views 3 Replies Latest reply: Apr 1, 2010 11:13 AM by ricksox RSS
DannyPinxten Just Startin' 2 posts since
Mar 25, 2010
Mar 25, 2010 12:28 PM
Backtrack  on windows 7 does not work or connect.
I've used the backtrack for a year, now I have installed windows 7 and my backtack does not work or connect whit my computer. Whats the problem? I have downloaded the setup utillity and it is posted on my pc but it does not work eather.
Greetz
  • ricksox UberGuru 11,600 posts since
    Mar 28, 2006
    Hello,
      I just connected both my BackTrack and BackTrack w.Mic to my Windows 7 machine here (dual boot 32 and 64 bits) and both devices were detected by both versions of Windows 7 just fine.
      The BackTrack has a Windows class compliant driver so it should be plug and play.
      How exactly is it not connecting? Have you tried ALL USB ports on your computer?
      What kind of computer are you using?
      Line6Miller
    Mar 28, 2006
    Hello,
      Have you tried performing a hard reset on the BackTrack? There is a little pin hole on the BT that you stick a paper clip into and reset the device. Try that first.
      If that doesn't work, try a new USB cable. If that doesn't work then connect to a different computer and see if it is recognized.
      If another computer sees it then you have a computer issue with Windows 7 which I may not be able to help you with.
      If it doesn't work on another PC then the BT hardware may be damaged.
      Line6Miller
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
