4941 Views 7 Replies Latest reply: Apr 2, 2011 3:52 AM by Mouley1 RSS
mdr88 Just Startin' 12 posts since
Jan 20, 2009
Mar 30, 2009 10:44 AM
Pod Farm Platinum Realtime Effects Monitor? Recording Software Recomendation?
Howdy do,
I own Pod Farm Platinum for iLok. Does anyone have any recomendations for recording software that will allow me send the signal into my Pod Farm Platinum and hear it before I record it? I currently own Acid Pro 6 and I have a copy of Acid Studio Pro7. It seems that I can only apply effects to a track that has been recorded. There doesn't seem to be a way to play my guitar and monitor the effects with my Pod Farm Platinum iLok activated software. I connect my guitar using a Line 6 Guitarport. I also own an Alesis Multimix Firewire mixing board. Using either of these I can her my signal, but when I activate my Pod Farm Plat Plug-in It's still a clean signal. Is there a way to actually hear Pod Farm Platinum effects realtime monitoring before I record? I am a rookie. =)
Or maybe that's just how Pod Farm Plat iLok works? You can use it to apply to tracks already recorded? Maybe Acid Studio 7 just doesn't have that feature and maybe I should use different recording software? Any recomendations or advice would be cool. I am new at this.
Thanks!
  • mimungr Gear Head 649 posts since
    Mar 25, 2007
    I've never used ACID, so I can't help you there. I use the iLok POD Farm Platinum plug-in with Adobe Audition 3.0, and I'm able to monitor the inputs with effects applied, so it's not a limitation of the plug-in.
  • geeker Iknowathingortwo 1,163 posts since
    Jan 26, 2007
    have you tried putting POD Farm in the effects send or insert of a track. How about in the input channel's insert?
        Jan 26, 2007
        have you tried the same input without the POD farm plugin? Are you getting a signal in ACID at all? Are you opening POD farm up as a stand alone or as a VST plugin?
        sorry to ask all these questions. I wish I could see your computer to help ya out.
        I set POD Farm in my Cubase 5's input channel when I want to record what I hear. Now if I want to record a dry track while monitoring through POD farm I would open it up in a send channel.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
