Apr 28, 2010 3:02 PM
Modifying channels on FBV Express Pedal
Like (0)
Hello,
Maybe I'm nuts, but for the life of me I have not been able to figure out how to change the sounds on the A/B/C/D foot switches. I'm running the express pedal through a SpiderJam amp. If anyone can take me through this process step by step it would be greatly appreciated. The manual does not explain how to do this.
Thanks!
you're right, the manual doe snot lay this out clearly. You have to piece it together.
these may help:
from the user manual page 3-2
User –• 36 great-sounding presets that you can overwrite with your own custom tones. The User presets are numbered 1A - 9D and can also be recalled using an optional FBV foot controller. Check out Appendix B for more info. A factory reset (see page 3•2) will restore these presets to their factory defaults.
also check this
and this
Hello,
This information is correct. When selecting A B C D on the express you should see the presets change accordingly on the amp. If this is not working correctly you should take a look at the following FAQ for trouble shooting.
http://line6.com/community/docs/DOC-4501
Please be sure to leave points for end users who assist you!
