1154 Views 3 Replies Latest reply: Apr 30, 2010 1:30 PM by Iwanarock RSS
rockn-rich Just Startin' 13 posts since
Mar 22, 2010
Apr 29, 2010 5:41 PM
Tones for flextone II
Can I use my POD xt as a midi interface to get tones for my Flextone II ?
  • Iwanarock Just Startin' 10 posts since
    Jan 30, 2007
    Apr 29, 2010 10:30 PM (in response to rockn-rich)
    Re: Tones for flextone II
    If I understand what you are asking I do not think so, but I never tried it. If you are trying to bypass the flextone power amp thru midi I don't think you can. I purchased a Marshall a few years ago but I still have my Flextone II HD and I used to use my POD XTL with it to generate additional tones and it actually worked quite well. I gigged with this set up for a few years, But what I did was I developed a really clean very flat EQ patch on the flextone and then ran POD XT tones on top of it. I also played around with various Cabinet emulations on the Flextone clean patch and saved several version of the Clean flat EQ tone with different cab emulation to use with various POD XTL tones. I also had a blank patch with nothing enabled on the POD XTL that I would use when I wanted to use Flextone II HD tones. I actually got some really good tones doing this. So it is possible to expand your tonal options with a little work.
  • Line6Andy Line 6 4,345 posts since
    Jun 5, 2006
    Apr 30, 2010 11:54 AM (in response to rockn-rich)
    Hello,
    You will need a MIDI-USB interface to download tones to your Flextone 2.  See the following links for more information:
    http://line6.com/community/docs/DOC-1484
    http://line6.com/community/docs/DOC-4287
    http://line6.com/community/docs/DOC-3783
      Jan 30, 2007
      Apr 30, 2010 1:30 PM (in response to Line6Andy)
      Good catch Andy I think I may read hs post wrong. If you are just trying to load additional tones to your Flextone II then no you cannot use your POD XT as your midi interface to get tones to your flextone II. You need midi sport uno adapter to do it. USB to your PC and Midi in/out connectors to your flextone II.You will also need Line6 Edit from Line 6 site. Below is a link to the adapter they are only like $30-40. Good luck.
      http://www.m-audio.com/products/en_us/Uno.html
Bookmarked By (1)
