2498 Views 25 Replies Latest reply: Jul 18, 2012 5:39 PM by DanDameron RSS
dxdgenert Just Startin' 12 posts since
Mar 5, 2009
Apr 30, 2010 8:01 PM
Distortion, clipping and cutting out with Toneport UX1
When using my UX1 I am experiencing distortion, clipping and cutting out of audio.  This occurs whether I am in POD Farm, listening through iTunes or system sounds.
I have all of the updated drivers 4.0.2.7 for the Toneport.
I am using an Alienware computer with AMD Athlon X2 Dual Core 3800+ 2.01 GHz CPU, 3.00 GB RAM running Windows 7 Home Premium 32-bit.
I have tried the generic "cookie-cutter" response that Line 6 gives out to no avail.
This unit is completely useless.  What should I do next?
  • ricksox UberGuru 11,600 posts since
    Mar 28, 2006
    Hello,
      Cookie cutter or not I need to do my part and make sure you have tried the following. If you have, please download the attached doc, fill it out, and re-attach it to your reply in this thread. Thanks.
      1. Fill out your support profile at http://line6.com/account/supportprofile/
      2. Ensure that you have tested all cables to make sure that they are not defective (USB, audio, etc.)
      3. Ensure that you have all cables connections set up properly
      4. Adjust the Buffer Slider in the Line 6 Audio MIDI Control Panel. (Windows Users: Start/All Programs/Line6/Tools/Audio-MIDI Devices; Mac Users: System Preferences/Other/Audio-MIDI Devices)
      5. Adjust Sample Rates and Bit Depths in the Line 6 Audio MIDI Control Panel and ensure that the Sample Rates and Bit Depth settings in the Line 6 Audio MIDI Control Panel also match the project settings in your DAW/recording application
      6. Ensure that you have the Line 6 device set up in your operating system as the main input/output device (sound card); disable internal sound card in your operating system’s Device Manager control panel
      7. Ensure that your Line 6 USB Device is not connected to a powered USB hub; direct USB ports are required and please try ALL available direct USB ports during the troubleshooting process
      8. Remove all non-essential USB peripherals from the computer (not the mouse or keyboard)
      9. Disable any wireless cards on computer in Device Manager
      10. Set Power Schemes on computer in Control Panel (PC Only) to Always On
      11. There are also several other tips and optimizations you can make on your PC. Please refer to the following document for more information:
      http://line6.com/data/l/0a06007213339477ea0690cb2a/application/pdf/GearBox%203.5%20and%20later%20Windows%20XP%20&%20Vista%20Audio%20Tips%20&%20Optimizations%20(Rev%20A)%20-%20English.pdf
      Line6Miller
    Mar 28, 2006
    Hello,
      You may want to try disabling the PowerMizer settings for your NVIDIA card. That's helped a few people so far. You can download a little application called Nv GPU Pro from http://www.nvgpupro.com/.
      If that doesn't help let me know and we can get a ticket going for you and see if there is anything else we can do. Thanks.
      Line6Miller
  • Kneehow UberGuru 6,750 posts since
    Dec 26, 2007
      We've created a support ticket for you so we can resolve this issue offline. Please respond to the ticket. Thank you...
      A support ticket allows you to directly correspond with a Line 6 Support Representative. An email will be sent to you from Line 6 containing a link if a Line 6 support representative determines that a ticket is necessary to troubleshoot your issue. Please follow the link in the email to view your open ticket to work one on one with Line 6 Support.
      Please note: Sometimes support tickets will be filtered to spam and junk folders. If you did not receive an email from us indicating that a ticket has been created, please make sure to check those folders in your email host.
      http://line6.com/account/tickets/view/
      What is a Support Ticket?
      http://line6.com/community/docs/DOC-1422
      Regards,
      L6Perry
    Mar 28, 2006
    To be completely honest with you. This issue could be with our driver so it may be a while before it's fixed. I just don't want you to think you'll see a patch update in a week.
      Line6Miller
  • Line6Hugo Line 6 6,580 posts since
    Apr 8, 2007
    All that can be done is to continue support through the support ticket that was opened for you.
    Regards,
    Line6Hugo
    Apr 8, 2007
    I'm sorry for the inconvenience, but we are diligently working to resolve issues that you and other customers are experiencing with any of our products. The support ticket is being reviewed by our test department for further investigation in the problem you describe.
      Regards,
      Line6Hugo
    • ferroaj Just Startin' 4 posts since
      Sep 10, 2008
      I'd like to state that I'm having a similar issue... the toneport is a great product, and that's why I spent 150 dollars on it, yet it's sitting in my room collecting dust because your DRIVERS are bad?!  are you KIDDING me?!  Something needs to be done here and quickly because if your car you just bought suddenly stopped working and the manufacturer told you "oh.  it could be the engine, so it might be a while" you would NOT be happy.
      Just saying
      • misza Just Startin' 7 posts since
        Aug 18, 2010
        Same thing here. I was using Toneport UX1 with a windows XP system and it was working fine, but I needed a new machine with more RAM and HDD space for DAW. Now i get cracking sounds every few seconds and therefore the device is USELESS for my recording and that was exactly what I bought it for. I tried all the tips and tricks for speeding my WIndows up, but they DO NOTHING. My system is pretty new and has more horsepower than I need, still Line6 claims I do something wrong. I never started a thread myself, becouse I see that it is hopless, couse ppl having same problem as mine get silly answers from Line6.
        It's not my fault that Windows 7 is so popular right now, and it is not my fault that DAW + VSTi need a lot of RAM.
        I think that Line6 lost it somewhere few years ago while inventing too many new stuff. They need to face facts:
        -Windows 7 is preinstalled in majority of PC systems right now.
        -64-bi Windows 7 is needed if you need 4GB of ram or more, and you DO NEED IT FOR DAW and VSTi.
        -People need stable drivers and not some TIPS and TRICKS for speeding win7 up. Those tricks dont work.
    • rockerbill Just Startin' 1 posts since
      Apr 28, 2010
      Guess what i have the same issue & yes it is a driver issue that line 6 need to get sorted, so at the moment line 6 do not have a working windows 7 driver.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
