4017 Views 8 Replies Latest reply: Dec 11, 2012 3:55 PM by LukeOxendale RSS
foxdie Just Startin' 3 posts since
Mar 26, 2009
May 11, 2010 2:27 PM
Line 6 Monkey unable to connect to Line 6 web servers (Code 8000204E) Sockets: Timed out.
I've been using my X3 live for about a year now, I had it plug into my dekstop computer that was running Windows XP and everything was well, no problem what so ever.
Till recently, i bought a laptop running Windows 7, and after installing Line 6 Monkey ver 1.33, i couldn't connect to the Line 6 web server for update. I can login with my account just fine, just that it would not update.
I check over some solutions regarding the problem and had done the following:
1. Disable all anti virus programs
2. Disable all pop up blocker from Firefox and Internet Explorer
3. Turning off firewall
4. Running Line 6 monkey with right clicking "run as administrator"
5. Trying both wireless and lan cable connection
6. Reinstalling Line 6 Monkey
7. Rebooting after installation
After trying all sorts of method, i still get the same problem. I don't know if this has anything to do with the new OS Windows 7 because i absolutely had no problems with my desktop running Windows XP before. Besides this, Line 6 Monkey is also not recognizing my X3 live. I had it plug in to my laptop via USB, trying all the USB slots available but no luck. I already have the latest 4.0.2.7 drivers for Windows 7 installed.
My laptop specs are as the following incase you're wondering
OS: Windows 7 Ultimate 64 bit
Processor: Intel Core i5 m520 @ 2.4Ghz
RAM: 4 GB
I will be grateful to get any sorts of suggestion or solution to my problem. Thanks!
  • ricksox UberGuru 11,600 posts since
    Mar 28, 2006
    Hello,
      Are you trying to connect to our server through a wireless connection or are you using an ethernet connection?
      Line6Miller
  • Line6Andy Line 6 4,345 posts since
    Jun 5, 2006
    Hello,
        Are you connecting using a USB hub?  If so, this could be the issue.  Se the following links for more information:
      USB Connectivity with Line 6 Devices
      http://line6.com/community/docs/DOC-1484
      See the following link for more installation and setup information, as well as driver install info:
      Installing Line 6 Software for Windows 7 Operating System
      http://line6.com/community/docs/DOC-1885
      If you are still having problems you should try your computer on a different internet connection to see if this resolves your issue.
      If you need further assistance, please provide the following information:
      •     Line 6 Product:
      •     Flash memory, USB Firmware  versions installed:
      •     Line 6 Monkey version installed:
      •     Line 6 Drivers version installed:
      •     Line 6 Application (i.e. Riffworks, Line 6 edit, Gearbox) software and version:
      •     Operating System version
      •     Is this a dual boot system?  If yes, please list all applicable operating systems:
      •     CPU / Processor Type and Speed
      •     Amount of RAM
      •     USB Ports: (#, location, speed 1.0/2.0):
      •     USB Devices connected to on your system: (Including any HUBs):
      •     Security software installed on your system (anti-virus, pop-up blockers, firewalls):
      •     Audio recording programs on your system (i.e. Sonoma, Ableton, Cakewalk, Pro Tools, etc):
      •     Audio playback programs on your system (i.e. Real Player, Winamp, Itunes, WMP):
      •     Type of internet connection: Cable modem, DSL, satellite, dial up:
       Please note: Line 6 does not support satellite or dial up internet service
       General troubleshooting questions (choose N/A if it does not apply):
      •     Does Line 6 Monkey recognize your device?
      •     Have you reinstalled the drivers for this device directly from the Line 6 website for your OS?
      •     Are you connecting directly to a USB port on the back of your computer?
      •     Have you tried different USB cables and ports?
      •     Have you shut down all security software/other programs?
      •     Have you tried to replicate the problem on a different computer?
    Mar 28, 2006
    Hello,
      I've run into this error before on my own laptop. One thing that resolved it was turning off my wireless card while I was connected via ethernet.
      Can you try this and let me know if it works? Thanks.
      Line6Miller
    • OMSON Just Startin' 1 posts since
      Sep 3, 2009
      I have only wireless connection and the same problem (Code 8000204E). My OS is Win7 Ultimate 64-bit, USB card is TP-Link TL-WN422G, firewall rules is right and I'm sure that is nothing block Line6 Monkey... So what is the problem?
      Early I was successful activated my GX on notebook with the same OS and kind of connection (integrated wireless card Atheros) and another regular PC computer with wired Ethernet connection (OS is Win XP Professional SP3 32-bit)...
      Give me some advice about retrieve this error, please.
      Ok - I have solution about an error (code 8000204E) Sockets: Timed out!
      Wireless connection bring an error when is trying to login Line 6 server, becouse Line 6 Monkey is dependent for MS Internet Explorer LAN preferences...
      When default is proxy - then Line 6 Monkey cannot correctly login. So only what to do is change this setting on automatic configuration (go to IE-->Tools-->Internet options-->Connections-->Lan preferences-->uncheck 'Proxy server' and check 'Automatic detect settings'). Thats all...
      In the case, it's working.
      Message was edited by: OMSON
    Jun 5, 2006
    glad to hear you were able to resolve your situation!
  • LukeOxendale Just Startin' 2 posts since
    Oct 2, 2012
    I am having the same issue, except I have already checked the configuration, and "Automatic detect settings" is already checked.  What do you think is the problem?
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
