2354 Views 9 Replies Latest reply: Oct 29, 2010 2:53 PM by tumenibrother RSS
chaslock Just Startin' 5 posts since
Jun 4, 2010
Jun 4, 2010 10:18 AM
I have the axsys212 and need help !
I followed the "reset to factory default" directions and now my amp won't play. Its all over the place. The presets just scroll through the numbers. I can't select a preset or a user channel either. It just went bad after the factory reset attempt. I hope someone has a clue about this........I don't. I love this amp and really want to get it going again. Thanks, chaslock
  • tumenibrother Just Startin' 44 posts since
    Jan 27, 2007
    Jul 2, 2010 3:04 AM (in response to chaslock)
    Re: I have the axsys212 and need help !
    Chaslock
    I suspect a bad pot (or two).  When it goes "all over the place" does it display an "E"?  The display will either be "U" for user, "P" for preset or "E" for edit.  If a pot is bad, the Ax will automatically jump into edit mode as if you were changing a setting.  If this is the case, try to isolate which pot is bad (tap them one at a time and see if they change).  Line 6 will send replacement pots for free, rudimentary sodder skill is necessary to replaced it.  It may also be just a bad ribbon connection.  Open it ip and unplug/plug all the connectors, see if this fixes it.  If there is a bigger problem, good luck.  Tech on these is impossible as there are no more parts to be found.
        Jan 27, 2007
        Jul 4, 2010 11:23 AM (in response to chaslock)
        Since you get an "E", it is a bad pot.  What model do you have?  Axsys 212 or AX2?  If you have the Axsys, the control knobs are in "capture" format which means you have to turn the knob to the assigned value before it will change.  If you have an AX2 chip (even if you have the Axsys chassis), the control knobs may be in "Instant Access" which means as soon as you start to turn a knob, it immediately moves to that value.  For example, maybe you have the drive knob set at 25, but the knob itself was in the 3 o'clock position.  As soon as you touch the knob to turn it, the amp automatically jumps to a drive value of 75.  I suspect your system is in Instant Access, so the bad pot(s) jumps between different values and makes a mess!  To check what chip you have, press the AUX/MIDI and MAIN buttons at the same time.  If you have the original Axsys it will show v1.04 or 5, AX2 will be 2.01 or 2.
        Depending on the age of your model, to open it up, take out the screws on the handle, on the sides (usually two on each side) and any others on the top of the case.  Don't worry about the screws holding the metal corner protecters.  Once the chassis is out, remove the screws holding the removeable metal top plate (runs the length of the chassis).  Once in, you'll see the several ribbon connectors which you'll be unplugging when you remove the PC boards, so that will accomplish the unplug/plug portion.
        To get to the pots (yes, they are the knobs that control tone settings) you'll have to take out the screws that hold the PC board to the chassis, pull off the knobs and take off the nuts that hold the pot stem to the front panel.  Replace the old pot with a replacement.  These are not "off the shelf" pots.  Thye have a longer stem than what you might find at radio shack, etc.  Call Line 6 service department and ask for the replacements.  I've had 5 of these amps over the past 8 years and they've been very good at sending me new pots.
  • wspln Just Startin' 1 posts since
    Oct 29, 2010
    Oct 29, 2010 9:12 AM (in response to chaslock)
    I have the Axys 212 and need help as well- does anyone know if a footswitch is made that enables changing channels on this amp
      Jan 27, 2007
      Oct 29, 2010 2:53 PM (in response to wspln)
      Yes.  Its a "Floorboard", usually go for about $80-100 on ebay. Gives ability to do everything hands free except editing (move up and down banks, move between channels, tuner, live changes to turn on and off selected effects, volume and wah pedals).  I wouldn't (and didn't) use the amp live without the pedal.
