13594 Views 21 Replies Latest reply: Apr 28, 2012 9:03 AM by andrewpmast RSS
lowfreak Just Startin' 16 posts since
Mar 26, 2009
Apr 3, 2009 3:29 AM
No authorized device connected..
PodFarm has (apparently) lost contact with my KB37.. It worked for a couple of days, but after I got my Ableton live set up to receive midi from the KB37 it has reported "No authorized device connected. PodFarm cannot process audio".
I have restarted, I have changed usb-ports, I have reinstalled the line6 software, I have upgraded via the Monkey (which have no problem seeing the KB37), latest Drivers(3.4.3.2), USB Firmware(1.08), Flash Memory(1.03) etc.. My device manager list the KB37 as working properly. I can use the KB37 to record into Ableton, and to monitor.
So in short - it is only the PodFarm that cannot see my line6-hardware. Ironic isn't it :-)
What am I missing? Is this a common problem?
My system is WinXP (SP2), plenty of RAM and Disk-space.
My other soundcard is a Realtek (integrated with my Abit FP-IN9 motherboard)
Happy easter from LowFreak in Norway
  • Line6Sach Gear Head 1,351 posts since
    Oct 31, 2008
    Apr 3, 2009 12:23 PM (in response to lowfreak)
    Re: No authorized device connected..
    Which version of POD Farm are you using? The standalone should work, it is possible that you need to refresh your license for the plugin.
    With the KB37 connected, open Line 6 Monkey, click the 'optional add-ons' tab, click the 'Activate Purchase' button, type refresh & click 'Activate.' Follow the prompts that appear and try POD Farm again.
    Line6Sach
            • grame Just Startin' 1 posts since
              Jul 30, 2006
              Apr 6, 2009 7:57 AM (in response to lowfreak)
              i have exactly this problem with my kb37  - but only one of my windows partitions - the podfarm VSt plug-in says it doesnt recognise a hardware device even though the standalone version works fine.
              the podfarm plugins vst work fine on my internet partition. makes no sense. and annoying. i refeshed the activate in monkey which all went through ok. but my non-internet partition will still not run the vst plugs. in fact podfarm does seem to figure in the monkey window. surely i dont have to pay twice to use it on different partitions on the same computer?
              is there a support number i can call? weird support here.
  • Line6Andy Line 6 4,345 posts since
    Jun 5, 2006
    Apr 7, 2009 10:25 AM (in response to lowfreak)
    Re: No authorized device connected...
    Hello,
      I am suspicious that you are onto something regarding the partitions on your system creating the problem with your system.  You may want to try a different computer to see if the partitioning is the problem.  You should also remove all non-essential USB devices to ensure that the KB-37 is not getting "overlooked".
      Regarding your licenses, you only need to authorize the licenses in Line 6 Monkey, as they are "hard-wired" into the KB-37.  Please see the POD Farm User Guide for more information:
    Manuals
    http://line6.com/support/manuals/
    Line6Andy
    Please be sure to award Helpful and Correct points to community members who respond with helpful or correct answers!
  • ricksox UberGuru 11,600 posts since
    Mar 28, 2006
    Apr 7, 2009 4:49 PM (in response to lowfreak)
    Tell me a little more about the system you are having problems on. Do you have a USB hub connected to that computer? If so then that could be your problem. USB hubs can create certain communications issues between the plug in and the device acting as your dongle (device POD Farm plugin is tied to).
    Performing a refresh in Line 6 Monkey refreshes ALL assets simultaneously so you only need to do that once.
    Every asset (model pack/plug in) whether it is bundled with your device out of the box or you purchased it afterward needs to be AUTHORIZED via Line 6 Monkey on every NEW computer you connect to. Once you authorize on the computer a little authorization file is dropped onto said computer and this prevent Monkey from asking you to authorize in the future. The FAQ below calls out where these little .AET files are dropped depending on what computer you have.
    http://line6.com/community/docs/DOC-4738
    I've also created a video tutorial that takes you through the authorization process.
    http://line6.com/community/thread/4399?tstart=0
    When Monkey throws that "No Authorized Device Connected" error it usually means you have not authorized in Line 6 Monkey.
    If you are certain you have done that then chances are your issue is due to some sort of powered hub or even having multiple USB devices connected to your computer which can result in bogged down root hubs.
    Please let me know if this is helpful. Thanks!
    Line6Miller
  • JohnAss Just Startin' 1 posts since
    Mar 8, 2010
    Apr 12, 2010 4:24 AM (in response to lowfreak)
    I have the same problem, but i am using POD X3 Live pedal. Can`t I use that device with PodFarm. I have tried everything said in ths blog.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
