1785 Views 8 Replies Latest reply: Mar 8, 2013 8:05 AM by azraaell RSS
jonespwns Just Startin' 4 posts since
Jun 23, 2010
Jun 23, 2010 11:37 PM
Spider 2 combo amp volume problem
This problem has nothing to do with the presets... It is just that I will be playing at a normal volume then it will just jump to max volume! It startles me.. it's enough to give someone a heart attack lol. Is this a technical problem that needs to be fixed by taking apart the amp?
    Mar 26, 2007
    Jun 24, 2010 12:47 AM (in response to jonespwns)
    Re: Spider 2 combo amp volume problem
    I'm not familiar at all with any Spider amp before the Spider III series, but I suspect that your amp suffers from the same problem as the Spider III, IV, POD 2.0, POD XT Live and X3 Live and other DSP based devices - VIBRATION.   Vibration from loudspeakers can make potentiometers which have become slightly loose with age and wear & tear move very slightly.  With an analogue amp this wouldn't be as noticeable as with a modelling amp where everything is controlled overall by the DSP.  Presets include all settings except Master Volume which on the Spider series amps is the only analogue control.  All the others control what the DSP does.  If you park ALL the controls except Master Volume at zero and change to a new preset you will get the sound you expect at the volume you expect even though the positions of the control knobs suggest differently.  If on the other hand you leave your control knobs at what appear to be normal positions and then proceed to play loudly and say the Channel Volume control is a bit loose and set physically to 75% whereas the setting in the preset for that control is set to 50%, all that needs to happen is for the control to be vibrated to 74% or 76% and this new position information is immediately transmitted to the DSP which simply obeys the instruction to jump to the new setting.  Result = massive jump in volume.
    Park your knobs at zero and the problem should be minimised.
    Nick
        Mar 26, 2007
        Jun 24, 2010 9:58 AM (in response to jonespwns)
        OK - now you may have your answer I think.  Your (analogue) Master Volume Control pot seems as if it might be shot and needs to be replaced.  The vibration issue would definitely affect that too.
        It could be that your presets have somehow become corrupted and the Channel Volume setting has gone through the roof.  Try a factory reset and see if that helps.  If not i think your MV pot needs looking at/replacing.
        Nick
              Mar 26, 2007
              Jun 24, 2010 12:26 PM (in response to jonespwns)
              A potentiometer would probably cost about 50p here in the UK so about 75 cents in the US.  The problem you have is that you don't know the form factor, value or type of pot you need, and Line 6 don't normally give out that type of information.  You may get lucky if you can look at the existing pot and if it has a value and type stamped on it somewhere.  Then you have the problem of removing and replacing the existing pot.  If you're not comfortable with electronics and soldering irons etc... it is best left to someone who does know about this stuff.  it's not actually a difficult repair with the right part to hand for a competent amp tech.  You should take the amp to an authorised Line 6 Service Centre for this repair really, but given the age of the amp you may not think it worth spending a lot.  It depends how much you value the sound you get from the amp I suppose and what price you are quoted for the repair.
              Nick
  • Jamie81 Just Startin' 3 posts since
    Jun 24, 2010
    Jun 24, 2010 1:14 PM (in response to jonespwns)
    Probably seems a bit simple but have you tried resetting the amp to the default settings (Hold down A button when turning the amp on)? My Spider 2 has developed a problem where it just randomly turns the phaser effect on, resetting my amp seems to have solved this (although I did lose all my custom settings).
  • azraaell Just Startin' 5 posts since
    Jun 2, 2011
    Mar 8, 2013 8:05 AM (in response to jonespwns)
    i have discovered with my spider 2 that you can use the headphone socket as line out and plug it into the input of another amp, i have plugged it into a yamaha GA-10 and its great for my bedroom etc,using reverb and whatever effects you want playing through the other practice amp,with or without the treble/bass of the little amp, brings with it a new tone,and if you have a problem with volume of spider you dont have to fear death everytime you alter it,cos you can set it then alter GA-10! great! or whatever your practice amp is or amp of choice im liking it with or without volume issues of spider
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
