3100 Views 8 Replies Latest reply: Mar 1, 2013 10:26 AM by smackythefrog RSS
pvesper Just Startin' 5 posts since
Aug 13, 2010
Aug 13, 2010 11:27 AM
ux2/ podfarm 2 activation vst plugin sonar content
im sorry if this topic has been beaten to death allready. i thought ive read every related topic but i still cant figure out what im doing wrong..
i bought the podfarm2 activation key so i can use the plugin  on sonar 8, and no matter what i do, when i try to open it through sonar it gives me this
http://i38.tinypic.com/efmfyq.jpg
How do i fix this?
thanks and keep up the good work!!
ill post a link to a finished song when its done...
  • Krank678 Just Startin' 188 posts since
    Jun 22, 2008
    Aug 13, 2010 12:13 PM (in response to pvesper)
    Re: ux2/ podfarm 2 activation vst plugin sonar content
    When you say, "no matter what I do..." what have you actually tried?
    This may be seem like a silly question, but did you manage (via Monkey) to update/authorize your UX2 with the new Pod Farm 2 Activation Key? If not, close Sonar and run Line 6 Monkey with your device connected and authorize the activation key on your UX2. (That is assuming you have not already done this).
      Dec 22, 2006
      Aug 13, 2010 6:15 PM (in response to pvesper)
      have you gone through the sonar menus and added the line6 location to be scanned for plugins?
      i dont use sonar... but it should have some variation of this... meaning that on windows  pod farm is typically in a program fles\line6 folder
      but that folder isn't typically the vst folder... its usually something like porgram files\steinberg
      anyway some daws find them anyway and some don't you may have to either copy the line6 stuff into the default vst folder or change the default vst folder...
      depending on the daw you might just be able to add another folder location for vst's in addition to whatever the default is.
    Jan 27, 2010
    Aug 16, 2010 8:11 AM (in response to pvesper)
    RE: ux2/ podfarm 2 activation vst plugin sonar content
      I think you have already tried this, but are you sure you activated the plug in in monkey?
      In monkey:
      Got to the Optional Add-Ons Tab and click active purchases.
      Also, are you using a line 6 interface or ILok with a third party interface?
      Thanks,
      David
      Line 6 Customer Support
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
