2203 Views 5 Replies Latest reply: Jun 3, 2012 8:30 PM by john_burfy RSS
eyegotit Just Startin' 1 posts since
Jan 3, 2007
Aug 16, 2010 5:41 PM
Pedal dock malfunction
I have a ToneCore pedal dock that does not work properly.  I actually have two ToneCore pedals one of them no longer allows the module to effect the guitar signal.  I know it is the dock because I switched the modules in the two pedals.  Both modules worked with one dock.  Neither of the modules worked in the other dock.  So, is there anything that can be done to fix the bad dock or is it trash?
  • Kneehow UberGuru 6,750 posts since
    Dec 26, 2007
    Aug 17, 2010 3:55 PM (in response to eyegotit)
    RE: Pedal dock malfunction
      Unfortunately, no. With ToneCore pedals, those units are non-serviceable ones. If you're still within the first year of new product purchase (on your store receipt), we can help you out.
      But if you're outside of that time frame, you'll need a new dock. Our dealers sell just the dock... most likely special order items.
      Regards,
      L6Perry
    • designermx2 Just Startin' 1 posts since
      Apr 27, 2010
      Feb 29, 2012 5:12 AM (in response to Kneehow)
      Re: RE: Pedal dock malfunction
      I have problem too. The pedal has two years. You can't sell only the board? This is more especial price, because we have the dock metal base (mine is new) and my problem is only the board. I have two docks and 3 modules. Now, only one works.
  • jrucker00 Just Startin' 3 posts since
    May 17, 2012
    Jun 1, 2012 1:34 PM (in response to eyegotit)
    Re: Pedal dock malfunction
    Hi Everyone,
    I just bought this pedal a week ago. Right out of the box, I tried implementing the stock 2-band EQ that comes with the ptoduct.  When I do this, the software says the .cpl file was installed successfuly.  However when I test this, none of the controls work.  All I get the same signal I put in with unity gain, regardless of where any of the knobs or switches are set. I can't change the EQ, gain, or volume.
    I have tested both audibly and through an oscilloscope. Can anyone help? Do you think my doc or module is malfunctioning?
    Thanks.
    -Justin
      May 17, 2012
      Jun 1, 2012 2:32 PM (in response to jrucker00)
      To clarify, the software registers that the knobs are turning (the gui shows my knobs moving as I turn them).  Also, the LED does not turn on ever.  I am led to believe my dock is malfunctioning.  Please advise.
  • john_burfy Just Startin' 1 posts since
    Jun 3, 2012
    Jun 3, 2012 8:30 PM (in response to eyegotit)
    Its a little tricky which brand to buy for pedal..any suggestions
    Executive Leadership Development
    http://johnmurphyinternational.com Certified Executive Coach
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
