1262 Views 3 Replies Latest reply: Mar 17, 2013 3:51 AM by ihventura RSS
chrishlp Just Startin' 9 posts since
Feb 3, 2008
Aug 24, 2010 1:20 PM
High frequency noise
Hi, Recently bought a Spider Valve MkII 112 and have noticed that when running the amp I am getting a high frequency noise (constant pitch with slight variation, similar to digital noise from a computer).  It is not load enought to be noticeable when playing but is anoying when not.  It is not present when using the DI out and goes away when I engage the tuner.  It does not matter whether I have a guitar plugged in or not.
The amp is only a few weeks old, do I need to take it back to the shop?
Any thoughts??
Regards,
Chris
    Mar 26, 2007
    Aug 24, 2010 1:35 PM (in response to chrishlp)
    Re: High frequency noise
    Hi
    You could try the amp in another location just to rule out there being local interference external to the amp.   The problem would seem to be in the power stage of the amp as you say it goes away if you connect to something else using the DI output - does the noise also stop if you change the mode of the DI output to Performance Mode?
    You could also try the pencil test to check whether any of the valves may have become microphonic (the pencil test refers to a method whereby you take an insulated stick like the casing of a biro and lightly tap each valve whilst listening to the speaker output - any noticeable microphonic output generated by any valve indicates the valve needs to be replaced)
    However, if the problem isn't microphonic tubes or something at your location, then you should take the amp back to where you bought it and get them to verify the problem and to exchange the amp for a new one if you can - in my opinion.
    Regards
    Nick
  • spaceatl Expert Line 6 User 4,456 posts since
    Jan 24, 2007
    Aug 24, 2010 1:57 PM (in response to chrishlp)
    +1 on trying other locations...sounds like interference of some kind...
    try turning off any nearby WiFi routers, phones...ect...anything high frequency wireless...My router adds some weird things on signal if I get too close to it...Try using a power conditioner with noise suppresion if you are not doing that...
  • ihventura Just Startin' 32 posts since
    May 7, 2009
    Mar 17, 2013 3:51 AM (in response to chrishlp)
    I have this problem too.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
